SOURCE: "Synchronize to continue your subscription"
To get rid of that message, you need to connect your Sansa to your computer and open the Rhapsody software to "deauthorize" your Sansa (assuming that you're not going to be using the Rhapsody service). The following URL gives you two options on how to deauthorize your device (look at the bottom section of the page): http://home.real.com/product/help/chandler/en/instruction/auth_deauth_pd-textonly.htm
SOURCE: Can't copy files to and from Windows Media Player
If the music service subscription that you originally used to transfer these files has expired, then you will get this error message.
Also, you have to fully resynchronize to the original computer yo connected the player to every 30 days.
SOURCE: error on downloading audio books
The new Sansa c200 series devices come with some songs on them from the factory and apparently they are in a special format.
All I had to do was fomat the device using its Settings Menu choice.
It wiped everything off the device, but then I was able to sync any song over to it using my Yahoo Music Jukebox software.
SOURCE: trying to transfer audio book from itunes or windows media player
Make sure the usb mode is msc Open my computer click sansa open sub folders delete from here or right click on Sansa select format this will delete all....Try and drag and drop the audio book into the folder assigned Here is the link for the manual and update firmware plus the media converter (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe)
Once you have the audio loaded and it works sync and try with your WMP......Hope this works
SOURCE: Loading audio books onto sansa fuse clip 2gb mp3 player
You need to tag the .mp3 so it has a genre of "Audiobook". Google "mp3 tagger" and you'll find utils to do this for you.
