SOURCE: Transcend 8 GB Pendrive showing write protected
Think this write protection error is due to some virus.
Steps to remove write protection for Transcend users
1) Go to download center of the transcend,here is the link
http://www.transcendusa.com/Support/DLCenter
Type the model no. or part of model number you are looking for.
example: JFV30(all alphabets in Caps )
2) Choose other details like product type etc. and search for your product
3)Then select the product which which is most similar to yours from search results
4)Then download the mFormat utility. You will asked for serial no. if you dont have..enter this no. 1456784523
5) Connect your pen drive
6) run the mformat utility and select full format after full format your write protection will be removed. try twice or thrice if you can't correct at first time.
Thats all...
It worked for me and my friends....
Other pen drive users may visit there vendors site and download any fromat utility present there for your model.
SOURCE: i hav 4gb pendrive of transcend.It cant be formatted becoz of wri
hi
go to this link
http://www.transcendusa.com/Support/DLCenter/index.asp?LangNo=0&Func1No=11&Func2No=182
put your model name of your pen drive and search ... you will get the software to remove write protection.. install that software and remove write protection..
thats all...
have a nice day..
-rajkumar
SOURCE: Pendrive Transcend 8GB JFV10 error message "Disk is Write Protected"
Thats all...
SOURCE: Transcend JetFlash V60 16GB pen drive is write protected
Flash drives by default use the FAT32 file system. FAT32 has a limit of 4gb per file. So you could have four 4gb files on your pen drive, but no files bigger than about 4gb. You could use the NTFS format, but it's not suggested for flash drives since it reads/writes much more often than FAT and will make the drive lifetime MUCH shorter.
Testimonial: "It is not 4GB per file ! The 16GB Transcend pen drive is accepting only files upto 3.71 GB only. After reaching 3.71 GB it gives a message. "
If you do not have a write protection switch on the drive itself, you must download utility called Jet Flash recovery Tool form transcend website and
use it recover your pen drive.
you can also download the recovery tool from this link also:
http://rapidshare.com/files/261372396/JetFlash_Recovery_Tool.zip
Please vote appropriately and leave a response. I hope this helps and good luck.
