After full charging also battery showing low battery
You can install LEO Privacywhich can largely reduce cell phone power consumption, extend battery life.
LEO Privacy Applock Hide Safe Android Apps on Google Play
SOURCE: nokia 1100 shows battery low even after full
your mobile battery is dull check battery first by using another mobile
SOURCE: my nokia N73 mobile phone
This is a very common problem with the nokia N73 phone,
The problem you are experiencing with your phone is not from the battery but rather from the panel of your phone,
The panel of your phone is corrupted,hence its irrationally discharging the battery rather than storing up the charge.
The solution is to ;
1.take apart the phone,
2.Conduct a thorough cleaning and servicing of the phone panel.
3.If problem persists,it means the panel of your phone is gone and needs a replacement.
Best of luck!!
SOURCE: i have nokia 6120c charging
You will need to check your adapter and also the voltage that comes to the battery at the charging terminals while the adapter is plugged on.
Since your new batteries are also not charging it is possible there is fault in the charger for not providing the sufficient voltage/current to the battery.
Finally it is possible that there are errors in the main board - charging circuit that prevents the desired levels of voltage required for charging.
SOURCE: 1600 nokia not charging after my sister change its
In nokia the generally the battery should be BL-5C so check it.if not change it coz the voltage of the center point of a battery are not similar.
Testimonial: "When i put another battery its done,Thanks"
