Our canon DR9080C is not detecting the ink for imprinter, I tried to swap the ink of the other DR9080C machine but still not detecting. when i scan using the imprinter it is saying "no ink installed". Thanks
SOURCE: installing new ink cartridge, canon pixma 1600
Go here. Type "how to install ink" in the search box. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures on how to prepare and install the cartridges.
SOURCE: Cannon IP1880 Cannot detect Cartridge
press the resume button 5seconds(this disable ink cartridge monitor..
SOURCE: Canon IR3300 would not scan when use the
If it is not an iR2200i with the i, then u cant scan
SOURCE: Canon MP520 cartridge swap and ink refill
Canon MP520
multifunctional device - deactivation of the ink level counter
1. You can do it only when the printer counter releases the warning message - "the ink
cartridge is nearly empty" = yellow
warning mark
2. You have to do this
procedure four times - for every cartridge one times
3. At the screen
you will see three warning messages
- for the first one press
"OK"
- for the second and third one press
"Yes"
4. The fourth
message tells you that you can do the ink level counter deactivation by
pressing the "Stop/Reset" button (7) for more than 5 seconds. Do it.
Later you can see another
type of warning message at the screen:
In this case you
can not follow the previous procedure - there will not be any other warning
messages.
Just follow the
message on the screen and press the "OK" button (5) and you can print.
Unfortunately - I do
not know for how long time it works.
You have to manualy
check the ink level and refill (change) the cartridge before it is completely
empty! You might brake your warranty!
When you insert the
new original ink cartridge, the counter will work properly again.
SOURCE: Canon MP610 ink refill
Without the resetter it will continue to give error codes, holding the resume button for 5-10 seconds sometimes will turn off ink level reporting, but you either need the resetter or to purchase and install reset circuit boards on each cartridge you refill.
i same doing same steps with the working DR9080C scanner, I even cleaned interface of the socket and the imprinter. The ink is working fine because i tested it in other machine.
