The place to put the batteries is blank. Is this why I can't put messages on. If messages don't go on this, I am annoyed, what can I do, can I exchange it????
SOURCE: how to get the messages of doro 615R+2 digital phone
down the bottom right corner , on the hash button, see the little x sign under the key, when you have listen to a message push that and it will be deleted then the next one will be heard and repeat untill you finish. hope this helps
SOURCE: doro phone
only just found this out as this was my previous question, but i just started fiddling with my ph. so here's the answer.
press the little c button (top right corner)wait for 5-6 secs then press 9, 180 will show on screen thats the amount of time to say message. to hear it repeat but press 7.
hopw this helps
SOURCE: PANASONIC KX-A144EXS
druk middelste knop ,nr verschijnt !
druk ronde knop rechts,
druk ronde knop naar beneden tot WISSEN verchijnt en druk dan ronde knop rechts en kl is kees
SOURCE: I want to leave my own answering message on my voicemail, how do I do that?
Press Menu. Then the unit will say "record outgoing message" Press the REC/Memo button and the unit will say "recording" and beep. The display will start counting in seconds. Speak your message. Press the play/stop button to stop recording the message will be played back to you.
SOURCE: DORO 830R cordless phone replacement battery
simply just goto the website search for the battery needed within your place.
