I think you will need to access the Nav System with a professional
scanner or scan tool & then use manufacture trouble charts, to even know what the system is supposed to do, & how to diagnose it
Hopefully a repair shop, if they want the job,otherwise blow out
your wallet at a dealer
EMAIL ME ...
[email protected]
SOURCE: Toyota Camry 2008 Locked by Security System
The computer for the alarm is probably causing your problem. Scan the anti theft module to trouble shoot for the problem. You might have a door sensor that is shorted.
SOURCE: I can't disconnect my '98 toyota camry car alarm.
BEHIND THE DRIVERS KNEE PANEL IF IT IS FACTORY IT SHOULD BE JUST BEHIND THE DUCT WORK YOU CAN ALSO JUST UNPLUG THE PIGTAIL HARNESS IN BETWEEN THE IGN. SWITCH AND THE ALARM (PLEASE RATE THIS)
SOURCE: How do I change the starter in a 2000 Toyota Camry LE
i'm sure it's not the starter itself that is the problem, have the stater's solenoid checked...it might be stucked. It's quite a lot of work removing the starter but you can do it if you are willing enough to learn. You just need the right idea and tools to do it. Hope this will help save you bucks!
SOURCE: Disconnected battery cable but now it won't start?
there is two wires coming out of the positive cable and when you unhooked the cable the one that feeds your fuse panel may have came un plugged.
SOURCE: 1998 Toyota Camry wipers don't park and only work on low & hi.
Really from experience I will advice you have the wiper motor replaced.
Rate this solution.
EMAIL ME ...
[email protected]
