Really I've a Technics SC-DV170 System, and I love it, but I want to listen MP3 files, and see photo, and see films that I put into DVD Is it possible to do something with the laser reading module, upgrade it?. Change something, install a modern "Panasonic" DVD reading. Thank you very much for your answer Julio SIMONE (Italy)
The answer is simple if you want to listen to mp3 on your system and you purchased dv290 dvd changer you also need dv290 sound processor as they were coded - for example you have dv250 system with dv250 chager and sound processor you are only going to be able to see dvds and cds if you swap your changer to dv290 (plays mp3, audio ,wma and dvds) you also need to purchase dv290 sound processor as well - no need to change your amplifier or tape deck (the ribbon on the tape deck will be compatibile)
the lower end units were incompatibile with higher spec changers same when it comes to EH series if you have eh780 sound processor you are only going to be able to plug 780 changer or lower 760 770 etc... but 790 will not work with it unless you get 790 sound proc
SOURCE: How do I switch off demo on a sl-dv170 technics?
got the sc-dv290 model, not sure but I'd asume they are all the same
PRESS AND HOLD [-DEMO] until "NO DEMO" is displayed
SOURCE: technics ho2 no play error
u need a new motor in yr dvd player i had same problem so had new motor fitted cost 50 pound works now
SOURCE: technics sc-dv250
did you buy your system in adifferent region and moved with it to another? I heared something like some DVD players are region-locked. I could be wrong but google about region-lock... try this among others: http://dvd-player-software-review.toptenreviews.com/what-is-dvd-region-lock.html
Pikles
SOURCE: Technics dv290 system
i once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
SOURCE: FAILURE TO READ DISCS. TECHNICS SL-DV280 (SC-DV280)
if the disc starts to rotate when helped by hand then you definately have a weak spindle motor. dvds spin faster than cds which gives more wear & tear to the motor. i've repaired these faults numerous times. hope this helps?
