MY DVD player is a LG 19120W DVD/VCR combo and it wont play certain DVDs without a multi-region code I was wondering if you could tell me the code or a way of getting arond it
If you want to make your players region free, you can go to VideoHelp forum and then go to the DVD hack section. All you need to do is to type in a model of your DVD player and then search for the hack exclusively for your model.
You can also use some tools to remove region code such as Leawo Blu-ray Copy
You maybe able to get a region free code for your player from one of these WEB sites. www.dvdexploder.com/ www.videohelp.com/dvdhacks www.download-info.com/dvd/index_new.htm http://www.dvddemystifiziert.de/codefree_en/codefree.html
SOURCE: LG DVD player LG276
I picked up a LG DV276 DVD Player here in Australia but I am from the
United States so I own region 1 DVDs. I unlocked my new player by
instead 1. Open the tray. 2. Press 0 0 0 0 on the remote and a Menu
will appear. 3. Press 0 for region free. 4. Press pause and power off.
I can play everything now, Aussie and US DVDs. Thanks LJ66.
SOURCE: Playing region 1 DVDs in LG DR165 receroder
go to dvd set up then scroll dow to lock then push 0 seven times
SOURCE: Need Unlock code for LG RH266 DVD player
Just Follow these steps:
1. Turn on dvd player
2. Then it comes up NO DISC
3. Enter No 314159 using remote
4. Code displays on screen, press 0 and then pause
then turn off thats it.
SOURCE: Multi region code for my DVD player
open draw
press '0' 3 times
press which region (Eg 0 for multi)
press pause
and whola!!!
SOURCE: I need to change my DVD players Region code to play all regions.
1.Switch on unit 2.Press- Setup on the remote
3.Select the Lock option from the on screen setup menu
4.Press Lock on the remote unit ( under slide cover)
5.Press 0 7 times on the remote keypad
6.A message appears stating the unit is now Code free on the screen
7.Press Enter on the remote.
8.Close Setup menu and switch unit off.
9.Switch on and enjoy Multi-region DVD playing
please donot forget to rate this solution.
Thanks for using FixYa.
