In a 2003 Chevy Trailblazer, where is the valet-push button switch located?
SOURCE: replace low beam headlight on 2003 chevy trailblazer
I just replaced the low-beam bulb on my 2003 Chevy Trailblazer. The grill just needs to be loosed slightly. Then, raise two L shaped brackets, one on each side. For the inside one, I needed to use a flathead screwdriver to get to it. The light assembly can then be pulled out. Remove the rubber cover and rotate the bulb one quarter turn left to release it. Pull out the bulb, replace with a new one ($11.50) from Advance Auto Parts, and reverse the process. Once I figured it out, took about 10 minutes total.
SOURCE: Where is the fuel filter located on a 2003 chevy
Located in the fuel tank and can be reached by removing the back seat.
Good luck.
SOURCE: Locate 2003 Chevy trailblazer crankshaft position
The Crankshaft position sensor is located on the left rear of the engine block below the starter. it has an oval connector and is held in place by one bolt. See picture of sensor below (some models has a 45 degree connector, most are straight like the one pictured below.
SOURCE: where is the pcm located on a 2003 chevy trailblazer
5.3L Engine
The Powertrain Control Module (PCM) is located on the left front frame rail. The Powertrain Control Module (PCM) is located in the engine compartment. It is mounted on the left side of the engine.
4.2L Engine
