Volume is reversed on remote
SOURCE: Bose 321 system - volume is stuck at 30
You'll need to go into the main menu and there is where you can change your on volume, minimum volume, and maximum.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
SOURCE: Faint sound when watching TV with Bose GSX 321 System
I connected my surround sound to the audio output on my samsung tv and it works fine. Of course I don't have an hdmi input on my surround sound system because its an older model, but it works great. Just got to put the surround sound to audio instead of dvd or tuner setting
SOURCE: my child messed with the settings on my 321 bose
Reset all EQ settings to 0 for a starter. It sounds as if it is EQ'd down all the way.
SOURCE: bose 321 system stuck at 30 volume
Is vol buttons button on unit do the same, try remote.
If not try unplug from wall wait hour and try agian, if not bose update cd..
SOURCE: The volume control on my
On a Bose 38, the volume will self adjust at start, and then you will be able to change volume using either radio remote, or buttons on main unit (the one with DVD).
If the unit is not responding , then there is a fault.
A fault where the Bose 38 is working (eg. you can swap from DVD to AUX on bose), but you cannot control volume (you do not see the values on main unit display) is rather unusual.
Ensure that you have correctly connected TV, receiver, or any other external device to the bose in Input, not in output from Bose.
If you have an HDTV, use the optical input on Bose, that is the only digital audio in on a Bose 38.
Check if the problem depends on connections, if it does not, let me know.
