When set to a specific temperature, say 350 degreed; it will only heat to about 300 degrees. It runs about 50 degrees lower than the temperature set on the dial.
Try to locate the thermostat sensor in the oven. It will be long about 5 inches, thin and cylindrical with a very thin wire coming from it. It should be bright and shiny. If it isn't buy some paint on oven cleaner from Lakeland and carefully remove the dirt. It may take a couple of goes. The sensor wire can be brittle so treat it with respect. Lakeland also do an oven temperature guage at a reasonable price if you need to check the temperature.
Temp probe/thermometer inside oven dirty, or off attachment, or defective. On some models, a small screw head adjustment is provided to calibrate thermometer under dial knob. Else, I would just set dial 50 degrees higher rather than expense of new thermometer or dial.
