push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Try pulling the switch open, and clean the contacts, or make sure everything still connects as it should. Check your connections at the starter and solenoid.
Sometimes I have to push the cancel button on my Kitchenaid and start over and push the selection buttons again. and then push start. Don't know if this will help.
Common issue. Open doorAlarm will be going offLocate the antenna (should be on the windshield)Find the little black push button on the antenna.Turn key to the ON/IGN position (where all lights are on)WITHIN 5 SECONDS push the black button 1 time and release (unless your installer changed the number of pushes it should be 1)Within seconds the alarm will ceaseStart your vehicle.
If you have a B. Crocker bcf1690 machine you need to just plug it in and it will always default to the regular bread program. To change it to whole wheat you need to press the Menu button until the whole wheat program shows on the display ( #3) according to my manual if you go past it just keep pushing the menu button until it comes back around again to #3. then just push the start button.
