Cleaning
SOURCE: blade replacemen braun grinder
Insert a small standard screwdriver in the slot in the center of the bottom. Turn the blade slowly until you feel the screwdriver catch in the slot. This holds the motor still so you can simply unscrew the blade counter-clockwise. Do the same to hold the motor from turning while you screw the new blade on clockwise.
SOURCE: I need a user manual
There is a link to them on the Braun website. Here's a link to the English version:
http://www.service.braun.com/line/HH/H3045/H3045_2_NA.pdf
SOURCE: Braun KSM1 XXU coffee grinder stuck 'ON'
The little plastic piece is part of the spring tension for one motor brush. It has been re-installed. I no longer need any assistance.
SOURCE: Blade Change Braun KSM2 Coffee Grinder
There is a small slot on the bottom for a flat screwdriver to lock the shaft in place. Then unscrew the blade.
SOURCE: How do I oil motor on coffee grinder
There is food grade oils for just your purposed, greases also. Aplliance parts stores carry it
