Daewoo DTQ-19P2FC 19" TV Logo
Posted on Mar 25, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Daewoo tv dtq 21tips hsa no sound
I change the sound ic and still no sound
Francisco Mauricio G
Level 3:
Genius:
  • Daewoo Master 1,551 Answers
  • Posted on Mar 26, 2013
Daewoo Master
Level 3:
Genius:
Answers
1551
Questions
Helped
525397
Points
4192
Check if the IC got power supply and if not follow the line of feed for a bad resistor low ohms
4 Related Answers
Anonymous
  • 1284 Answers
  • Posted on Mar 22, 2007
SOURCE: tv not powering up
What voltage is present at the collector of the horizontal output transister? If the same 102 volts then you have no horizontal drive.
Anonymous
  • Posted on Sep 18, 2008
SOURCE: reset parental code on daewoo tv model dtq 19v1fc
necesito codigo para el tv de daewoo para un control philips
Anonymous
  • 105 Answers
  • Posted on Mar 24, 2009
SOURCE: My Daewoo TV is showing a yellow tinted screen...
this problem actually come from crt socket ic board (just patch behind the picture tube) need to properly clean and resolder back the joint please consult with your tv repairer and i think it not cost much
sodeep
Sudeep Chatterjee
  • 3267 Answers
  • Posted on Jun 22, 2009
SOURCE: Why do i just get a blinking standby light on my
Do you have the remote with you? Mostly the sets can be switched on for viewing only from the remote button.............sodeep
I need to purchase a daewoo model dtq 19p2fc remote
13 dollars on ebay. https://www.ebay.com/itm/Remote-Control-Daewoo-R-38T01-TV-DTQ-19P2FC-DTQ-19P3FC-DTQ-19V4FC-DTQ-20V1FC-K47-/253332809013
Menu for Daewoo DTQ-20U4SC TV.
Microprocessor error. Try unplugging for 10 minutes.
Service menu mode
You should first check the output voltages comes out from its main power regulator section; and to rectify the cause of this shut down first. Then only, there is any need to enter its service mode. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. Service mode entry, adjust and exit procedure to many brand TVs are given in detail.
Can iget the sound diagram for daewoo21t1ps tv ic audio sound
I've it. But how can I send it to you? It is in PDF format.
I change the i sound ic and still no sound on the daewoo tv 21t1ps
check the resistor who comes on the feed line of the IC sometimes they burn
My tv was working fine and now it has no sound to it, but i can still see the pictures and change the channels
Maybe the speakers are damaged,and if the speakers are good the problem are the Ic amplifier
Over sound when switched on tv
Hello
If the sound cannot be controled through TVs front panel controls or through remote control, your Tvs electronic volume control section is in trouble. It may be an Ic probelm or some loose contact in the printed circuit board itsef. Check it by somebody who knew through about it. Contact an experienced servic technician.
1helpful
I have a daewoo tv modle#is dtq-2040fc chasis #100b and i am not getting any osd so i cant see what channel it on , menu and the volume level
The OSD IC microprocessor might have a problem, try first try resoldering the joints on the pins , if that doesnt work check for leaky Diodes and transistors around the OSD Microchip, if all else fails the IC has be come faulty.
1helpful
NO SOUND
check first the speaker,if it is ok then check the also the amplifier ic.
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
