Gateway GT5040 PC Desktop Logo
joseph erickson Posted on Mar 25, 2013
How do i connect to the internet with a wifi
I have a clear wifi and noone can help me connect it
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Mar 26, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
0
Helped
871
Points
29
Maybe you dont have wifi reciever on your motherboard. in that case you should buy one that connects trough usb
An x error appearing not able to connect to wifi or go into any app
A problem we all have encountered ones at least. You can connect to your (new) WiFi network, but you donā€™t have internet access. We are going to fix the WiFi connected but no Internet problem in 5 minutes.
The error indicates that your (Windows 10) computer or phone can connect to your local network, but it canā€™t connect to the internet. To fix the problem, we first need to know the problem only happens to one device or all devices in the network.
I have split the solutions into multiple scenarios and listed the most common issue (and solution for it) on top so you can fix your internet access. After you applied any of the following changes it can sometimes take a minute before it has an effect. If you are using Firefox, for example, it will take a minute before Firefox clears its own DNS cache.
Apr 25, 2023 • Cell Phones
New Huawei mobile wifi.cant make it work.Please help.
switch off the phone and wait for 2mins and power it on then navigate to settings and diable WI-FI
How do I enable the wireless internet connection in my laptop? brand is fujitsu fmv lifebook#FMV-E8250?
go to control panel, click on internet connection click on establish find the wifi system in use then enter the code for the wifi system and it connects
Have amazon prime and cant keep a movie on it keeps going off and on
it is your wireless,make sure noone else is using your bandwidth,change your wifi password and get faster internet service
1helpful
3answers
How do I get my tablet to connect to a network, no matter where i go it says there is no connection even at the library, when i am physically inside
You likely have a setting to turn on WiFi. This option is to save your battery, as WiFi drains your battery if it is on continuously. If it is turned off, you will never receive a WiFi signal.
I reset my modem and now i cant get my wifi back on
If your modem pulled a new or different ip address and you did not reset your router it could be trying to use the old IP address and there would be a conflict. IP addresses usually have a lease of 24 hours, S if your IP was refreshed at noon and you reset your mdem and for sopme reason it obtained a new ip address the router would not be able to connect until noon the following day when it tried to refresh. Rebooting the router should cause it to sync back up with the modem and pull the correct IP address. You may need to log into your router and manually release and renew the IP address even after rebooting your router, I have seen a few routers that would still not pull the new address unless this was done.
My preferred method is to unplug power from the router, then reboot the modem. Only after the modem is synced back up do I plug power back into the router, so far this has seemed to work the best.
The my ps ask me securyti key for acccess at internet bat i don'no what is .....please you can me help?
The question seems incomplete or not clear but If you are trying to access a secured internet connection at your home or cafe through wifi connectivity, it will ask for the secured password or security key. If it is your home connection ask the person who set the internet connection, if is at a cafe, wifi spot ask the service provider. Hope i understand your question rightly.
34helpful
2answers
Dns failed error occured in s5620 samsung mobile .. when i use internet through mobil office or wifi
Hello
This sometimes happens in Samsung Cellphones that while connecting to internet via WIFI, DNS failed
To solved it follow the given procedure:
  • Go to browser
  • Then go to setting
  • Then clear cache, empty cookies and delete history
  • Now restart your Samsung S5620 cellphone, then connect to desire wifi connection, then browse after setting up your browser profile
If it doesn't solved then contact to Samsung Service providers and consult with providers of WIFI connection, But i hope it will work.
Don't forget to do Rating by Clicking on Four Thumbs which are given below to this solution if it is HELPFUL
Thanks and keep Using FixYa
7helpful
I'm having DNS FAILED each time while connecting to the internet via wifi. Please help.
Hello thanks for using Fixya
  • Go to browser
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using Fixya
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
