SOURCE: intel r pentium r dual
look at the brand of *********** board and download form there website.
SOURCE: audio driver of Intel Cpu Pentium Dual-Core E2180
look at the brand of your mainboard then download the driver from ther website.
SOURCE: CONFUSION WITH INTEL CORE DUO AND INTEL PENTIUM DUAL CORE!
You are worrying about nothing.
Intel Pentium Dual Core and Intel Celeron Dual Core are both Intel Core Dual processors.
The performance rate is mesured compared to a single core processor so your 2.2GHz dual core will do the same amount of work as a 4.95GHz single core.
Testimonial: "WAIT A MINUTE I NEED ANOTHER REPLY!SO WHAT YOU'RE SAYING IS MY PENTIUM DUAL CORE CAN RUN GRID?"
SOURCE: lenovo intel(r) pentium(r) dual cpu
check your driver in the device manager my rightclicking my computer hardware devicemanager then expanding audio controllors if you see any yellow mark the driver is not installed correctly reinstall the drivers if there is no yellow mark and your drivers are installed correctly go to control pannel click sound and audio device if you can see the volume slider and move it note the mute checkbox not checked if you still have problem if your system have sound manger go to sound manager and check the speaker configration
SOURCE: i want to free download sound driver for intel-r
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
