I replace all the mechanical parts thermostrat thermocapel gas tube sefety valve
SOURCE: pizza oven bricks need to be changed
You must use a long crowe bar lift the brick and pull it out need the size of the brick to let you know how much and where to get it if it a 2inch thick they are no longer sold most lilkely it 1 1/2 inch
SOURCE: thermo coupler on all the time, push in button, shuts off gas
Bad Safety valve. (valve w/red button). Thermocouple keeps the magnet open to keep pilot and so gas can flow to burner. Make sure pilot is clean and strong and hitting thermocouple. If it doesnt stay lit replace Safety Valve.
SOURCE: pizza oven does not light
thanx for the email reply .oven lighting problem was caused by the pilot light not quite touching the flame tubing
SOURCE: bakers pride pizza oven not lighting
Hello. Usually this problem is related to the pilot being dirty, and
not heating the bulb for the safety device properly/hot enough to fully
open the valve. If you have a general purpose mini torch you can heat
the metal bulb near the pilot with it, if this is the problem, the
safety will open, and the main burner will come on. CAREFUL, you are
not on/around the main burner, as it will allow gas to come on to the
main burner, and if your pilot is not working properly, might not light
the gas. Get the pilot cleaned and adjusted.
or... :) I know...
your safety has failed, allowing gas to the pilot, but internally is
not opening, this requires replacement. Last though, it could be your
thermostat, its last in line, and would require replacement. The
safety, and the thermostat are mechanical valves, open or closed
depending on its function.
If you have a more current type,
they will have a combination valve, and thermopile/thermocouple that
are electromechanical, your thermostat at this point can be either
mechanical, or electromechanical. This system has a few more possible
causes for your symptom.
You can tell which you have by how you
light the pilot, have a red button on the front of the unit, by the
on/off valve? this is the first type.
Have to open a small door to access a knob, turn it to pilot, and hold in? this is the latter type.
ask if you need more help.
Hope that helps, and thank you.
SOURCE: bottom oven pilot light goes out intermitantly.
adjust the flame so that it stays on the thremal couple and keeps it hot if it is off by 1/4 inch it will not work.
