Connected camera before installing updated software. Now cannot connect the new camera and am consistently getting 'communication error' when connecting to computer via usb port
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
SOURCE: lens not communicating with camera
contact problem or lens diaphram blades problem. First try to clean the contact with the pencil eraser. If the problem isn't solved. send it to canon it should cost you about 100.00 to repar.
