Anthony Gocha Posted on Mar 24, 2013
I need a copy of an owners manual for an Innovative Technology ITRR-501.
Has a CD recorder
ITRR-501 , No sound at all from the phono? Speeds are fine. Turntable starts and stops fine. I installed a new belt. Worked fine before? No sound, even when the needle is touched.
It could be a cartridge issue.
Here is the user manual for your reference.
https://www.manualslib.com/products/Innovative-Technology-Itrr-501-3527280.html
Innovative Technology ITRR-501 5-in-1 Wood Turntable CD RECORDER Music Center. How do you remove the turntable platter from an ITRR-501 cabinet?
Question edited for a lot more clarity.
Looking at the images and video, if you took the back off, doesn't that slot in the back come off with it? It you mean just a panel in the back, I would that a saw the the slot, sand it smooth and add a little mid oak stain to the cut edge. Then you will be able to lift the platter off. Or try and remove the whole turntable unit, lift the front and slide it out.
Did you know the turntable has 'auto-start'.
First make sure the display shows `` phono`` (press the right button under display ) Then release the hook that holds the arm in place , then lift the little arm right to the side that make the arm to go up and down. Then slightly push the arm to the left (towards the record) and it should start turning and position itself to the start of the record automatically. If not the belt may off or broken . Good luck
This says belt replacement, but is some guy with a flashlight in both parts 1 and 2!
1helpful
Record player doesn't move when I pick up the needle but it sounds like the motor starts. I hear a clicking noise when I move the needle to the record. Model ITRR-501
You can use a small screwdriver to remove the C clip in the center of the platter. Then remove the platter and reinstall the belt. It can be a little tricky to get the belt back on. If that fixes the problem, then I would look online and order a new belt as yours may have stretched out and will keep falling off. Here is a link to purchase the belt if needed.
NEW INNOVATIVE TECHNOLOGIES ITRR 501 ITRR 700 ITVS750 TURNTABLE BELT D001RX
NO SOUND
This is almost for sure just a connection that came out when moving or during shipping. Pull the back, off and look for some wires just hanging. Most likely it is an input.
Itrr-501 user manual
You may download a copy of the manual here.
1helpful
ITRR-501 NO SOUND DIAGNOSE
I was asked to further clarify problem, but not much to add when there is absolutly no sound it is called silence from the speakers when unit is plugged in, turned on (sounds like speakers engage) one of the five choices is chosen to listen to and no sound comes forth to hear. How can I get inside the unit and check to see the speaker connections?
1helpful
NEED operators manual for ITRR-501 retro 5 in 1. lost mamual. NEED TO KNOW how to record to CD Disc. Also will it record fro records to disc and record cassett to disk. PLEASE SEND me a manual. OR a zerox...
The unit will record to CD from the turntable, cassette or the AUX port. Place a blank CD-R or CD-RW in the CD tray. (Note: CD-RW discs may not play on other CD players.) Press the Phono, Tape or Aux button to select your audio source for recording. (For Aux, you will need to connect the source device to the AUX port in the back of the ITRR-501.) Wait for the CD disc to load and check for any indicator lights (you should see the "NO TOC" and "CD" or "CD-RW" lights lit). Select your Track increment (or Auto Manual for unattended track formation).Press Record button and the up arrow to adjust the recording level.
If you are recording from an LP, put the tone arm down on the record. For all sources, press Play. Press Stop to end recording or Pause to temporarily break the recording. Press the Track Increment button to advance the track number if you are doing so.
To finalize your CD-R to make it readable on all players: after stopping the recording, press the Finalize button.
The manuals for Innovative Technology products are available here: http://www.ithomeproducts.com/support . The products are listed in alphabetical order. The direct link to the ITRR-501 manual in English is http://www.ithomeproducts.com/sites/default/files/pdf/ITRR-501.pdf .
I hope this helps.
 Grubhead
Grubhead
SmartAviator
SmartAviator
