I have a classics six and it is less than a year old. Once I start the wash cycle it takes in water then immediately evacuates the water. I have to keep stopping it until it finally starts a cycle. At times it will keep beeping after just a few turns... Can you help please?
SOURCE: Washing Machine
yes you have a staket selenoid, knock the in take valve with havey like a plier, and you see, but any way replace the valve is better..good luck
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
SOURCE: No movement, then loud beeping alert
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
SOURCE: washing machine will not complete the wash cycle
The timer could be sticking OR: Is the machine empty of water when it stops? This information may help solve your problem?
SOURCE: Washing machine does NOT stop filling w/ water!
If the m/c keeps filling, where is the water going ??? if the m/c doesnt reach the required water level it will not start, check the drain hose at the back, make sure its at least 24" above floor level, if it lower then it will just empty as quick as you fill it on gravity.
