SOURCE: toshiba theaterview 50in rear projection tv
Look at it on the QVC channel where you have boxes with straight lines. If any of the 3 colors are bowed and 1 inch off, then it needs parts inside. If the colors are straight and only 1/4 inch off, you can adjust it. Using the remote, in the menus find convergence to adjust. Your user manual will explain it. At WWW.Toshiba.com you can download the manual if you do not have it.
SOURCE: Toshiba Theaterview Black Screen
yes its on your remote. its the c.capt button. or go under menu/enter and pan to the left untill it comes up. and turn it off by scrolling through the caption buttons
SOURCE: toshiba theaterview HD 52" has black box on screen
sound like to me caption 1 is turn on .. try going into settings menu and shutting off close caption...
SOURCE: broken plastic screen
After doing some searching what I have come up with is that your options are limited to contacting the manufacturer for a replacement screen or going the ebay route which looking there does not seem to have any possibility at the moment. You can also check with a tv repair shop preferably a mom and pop type joint, many of these places will have spare parts laying around.
SOURCE: toshiba rear screen projection tv theaterview
1.) It sounds like you have a convergence problem; in the customer menu with the original Toshiba remote select convergence--if blue or red will NOT move in some direction you have a bad convergence IC.
2.) This set uses 2 STK-392-110 convergence chips; they and any open resistors around them need to be replaced and the set adjusted.
3.) If you are able to do this repair yourself you can save a lot of money--Most TV shops will charge 300-400 for this type of repair on this set.
4.) If you cannot do the repair yourself look in your area--now is the slow time of year for TV repair shops---if they say it "has to go to shop" keep looking----almost any good tech can do this repair in your home in about an hour--I have done hundreds of them here and charge 200-250 total depending on brand and model.
5.) I am here to help people and if you have questions or need advice let me know--the two chips this set uses you can buy on Ebay for about 12 dollars plus shipping.
I do this here for free, so if this information has helped you give me a vote here---let me know by replying here if you need more help.
REGARDS SD TECH
