Question about American Standard Home
Water wont stop running - American Standard Home
    New Friend:
  • 22 Answers
Water is either running (1) into the overflow tube or (2) out to the toilet under the flapper at the bottom of the tank. If (1) lower the ball or float. Done differently depending on model. If (2) replace the flapper with new flapper designed for your model. (Note: Raise manually the float valve and if water still runs out the little tube that goes into the overflow tube then fill valve is defective. Replace it.)
Posted on Feb 01, 2014
6ya staff
SOURCE:
2005 chevy impala was running hot stopped put water in it now it wont start back motor turns over but wont start battery dead
Head gaskets blown or cracked head. It only takes 1 time of running hot to cause damage as the heads are aluminum and the blocks is iron.
Oct 13, 2016 | 2005 Chevrolet Impala
What is aquastop
I presume that when you say it wont stop running, it's the empty pump that is running. This is an anti flood protection. Water from a spill has got into the base of the machine and tripped the flood protection sensor. To cure the immediate problem, pull the machine out and tip it on it's side or back about 45 degrees and the water in the base will run out and the flood protection will reset. The real question is though, how did the water get INTO the base? Most common is that someone used household detergent instead of dishwasher powder or tabs and the foam it created worked its way into the base and then turned back to water as it settled. If this is the case, the tip sideways will be a permanent fix. If not, you will need to trace and cure the leak
Sep 23, 2015 | Bosch Dishwashers
Why won't water in door stop running?
The replacement valve could be defective.
Sep 19, 2015 | Refrigerators
How to stop my water heater from running
Check for water leak.
Turn off all taps and put ear against pipe
Make sure toilet or outside faucet are not connected to hot line.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 29, 2014 | Water Heaters
Changed thermostst and heater hose, car ran fine but leaked on right side of engine (Freeze Plug) now car stopped running while driving and wont start
sounds like the frost plug(freeze plug)let go and needs to be replaced. may have overheated the motor and it stopped due to overheating, as you say it was running and then just stopped and won`t start. just so you know the right side of the motor is the side facing the radiator as the pulleys face the drivers side. this is how a tech differentiates left from right on a Honda. fill with the proper anti-freeze and water mixture. this is all the help I can give you with the information you have supplied.
Jan 31, 2014 | 1992 Honda Accord
I have LGwm2016cw.. i get no error code. the washer wont stop adding water and it wont drain the water. any ideas
A small tube running up the side of the tub carries air prussure to tell the machine to stop filling.Mos likely the hose has disconnected.
Mar 21, 2010 | LG WM-2277HW Front Load Washer
Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Jan 31, 2010 | Whirlpool Inglis IP4400 Washer
My Bosch SHX46A06UC just runs and runs and wont stop.
The control board is not turning on the water heater due to bad control board, heater or limiting fuse.
May 10, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Home Logo
133 people viewed this question
Top American Standard Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
