Question about Honda Quincy 17 - Gallon Air Compressor with 5.5 Hp - G15H17PC3B
How much oil for a quincy compressor model #216
    New Friend:
  • 62 Answers
According to the owner's manual the Quincy QR 216 model has an oil capacity of 1qt. BTW, 1qt = 16oz. = 1.42L depending on your current measuring standard.
Quincy QR 25 216 Manual
Posted on Jun 17, 2015
    New Friend:
What type of gauge belongs on the side of a 216 quincy compressor?
Also were can i locate one?
Thank you!
Tom
Posted on Feb 02, 2014
6ya staff
SOURCE:
Air Compressor
No that is not the oil filter. The oil filter # is 110814-001 comes 6 to a pack.
Apr 11, 2014 | Quincy Compressor 110382D075 0.75 NPT...
Compressor shuts down and will not allow enough pressure run machine
Sounds like the oil is low or the cooler is dirty. If that's not the case then you have a defective thermal valve.
Dec 17, 2013 | Quincy Compressor Quincy QGS Rotary Screw...
My oil temp has gone from the ave of 140 to 152 in about a week. everthing else is normal
check oil level in unit as over full will over heat oil. It is possible that there is a failing bearing or bush. Check outlet pipes for blockages from carbon build up from un burnt sump oil.
Jan 28, 2013 | Quincy Compressor Quincy 5 Air Compressor
Where is oil sensor on honda gx160 5.5
The low oil sensor is on the front of the block the wires are attached to ur start stop switch. It has two wires yellow and black on most models. the sensor itself is internal
Dec 11, 2012 | Honda Quincy 17 - Gallon Air Compressor...
Quincy model model QMB/T is leaking oil out of filter
tighten filter
check that the filter is not too tight and distorting the seal
replace the filter
Oct 24, 2012 | Quincy Compressor Quincy 30 Rotary Screw...
What kind of Oil would you use in an Quincy Compressor Model 340???
30W Non-Detergent. You can get it at hardware stores or tool stores. You can go with synthetic if you like, but if you don't run it too hard, regular oil is fine.
May 26, 2011 | Air Tools & Compressors
When the comp. shuts off the air bleeds back out the intake. what needs done to stop this It is a quincy model 350 2 stage compressor
You have one or more valves broken in the head and need to be replaced, and Quincy compressors require a special tool to remove and install valves.
Apr 29, 2010 | Air Tools & Compressors
Compressor has no oil pressure but seems to be running good
If you're sure its not just a bad oil pressure gauge, and there is no pressure, the oil pump is probably bad. If you don't run it hard, it may still last awhile, running more like a "splash lube" compressor. Still, if this is a pressure lubed Quincy, it's a good compressor - I'd fix the oil pump and it'll last for years.
Dec 15, 2009 | Honda Quincy 17 - Gallon Air Compressor...
Honda Quincy 17 - Gallon  Air Compressor with 5.5 Hp - G15H17PC3B Logo
436 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Marvin
Marvin
Lawrence Oravetz
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
