I recently bought some new ebooks from Barnes & Noble & my nook down loaded everything fine-but then a few days later my nook library disappeared! My nook shows I have NO books in my library or on my shelves--I had 146 books!! How do I restore my library?
Download all the archived and unarchived books and save them to your computer. Never deleted these.
You have two options for the archived books.
Un-archive them and they will appear on your nook and download as you see fit.
OR... Sideload them. Which is probably what you did before since archived books already disappear from your My B&N Library and would have had to be in your My Documents Library.
Not exactly sure what you mean by 'does not go to my nook' when you try and save/download from the website.
If still having any kind of issue then you can take nook support from experts or call nook help number.
SOURCE: my sync continiosly spins, however
I've had the problem where my nookcolor would not sync with the B&N nook for pc. Updated the software to 1.01 and it worked until I hooked the cable up to my pc, then it stopped updating again even though I had ejected (safely remove hardware). I tried reseting the nook "hold the power button a few seconds and then press and hold the volume up button, release both when screen flashes. I have to repeat this each time I hook the nook to the pc and eject.
Joe
SOURCE: I recently bought a new
In order to start using your Nook, you'll need to register it through the Barnes & Noble website - I've shared the steps below. Once you've registered it, you will be able to start purchasing and reading books. Please note that you will need to set-up a B&N.com account first. That is done on BN.com and simply click "new user account." Once you have set that up, follow the below Nook set-up steps.
NOOK Set-Up Steps
SOURCE: nook hooked up for billing
make sure that the billing address is the same as the credit card's billing address, I believe that it does not except any address outside the USA territories or canada. I would log into the B&N website and go under account settings to payment settings and edit the info, if anything add the same card again, i had that issue and it worked after i did that. Hope that helps!
SOURCE: I just purchased a Nook
I assume you already have WiFi, if you don't, I suggest going out to wal-mart and buying a cheap wireless router to get you started. Then the instructions should explain how to get the password set up.
If you already have WiFi and the problem is that you forgot your password, then this should be able to be fixed easily if you know or have not changed the password for your WiFi router. Below is a set of steps to resolve the issue. The only requirement is a computer connected to the same router via WiFi or Ethernet.
1. Open Command Prompt (in windows) or open Terminal (in Mac OSX)
2. In the command line, enter "ipconfig" and press enter.
3. Look for Default Gateway and remember the corresponding IP Address. (Format: ###.###.###.###) It might look like 192.168.2.1 but not necessarily.
4. Remember that IP Address (write it down, copy it, do something).
5. Open your favorite web browser and enter that IP Address into the URL box.
6. This should ask you login, if it doesn't, skip step 7.
7. use the username that you set up the router with, or if you didn't change it, try using "admin" as the username and "admin" as the password. Try not using a password. If you still can't figure it out, use google to try and find the default password for your brand of router.
8. Once logged in, you can restore factory settings, or change your WiFi Password.
Having more information would have been helpful. (Aka - Router Brand, Is it your router, are any computers connected to it) Hope this was helpful.
