Computers & Internet Logo
Jerry Meyer Posted on Mar 23, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whats the purpose for System Bios shadowing? - Computers & Internet
Anonymous
Level 3:
Guru:
  • Master 2,178 Answers
  • Posted on Mar 23, 2013
Anonymous
Master
Level 3:
Guru:
Answers
2178
Questions
0
Helped
390290
Points
6614
System bios shadowed is the process of the contents of a ROM being copied to the RAM. This allows the computer to access that information quicker.
Solution system bios shadowed video bios
To "shadow" is to use a small amount of the RAM to hold a copy of the system-BIOS and the video-BIOS areas. This usually speeds-up the computer, i.e., use RAM that is faster than the RAM on the motherboard.
3helpful
System bios shadowed video bios shadowed
Was a good thing on old pcs. Not necessary on newer pcs to shadow bios or video. You may find increase in performance if you disable these in the BIOS settings.
7helpful
4answers
I recently dropped my acer on the floor. Now it is experiencing some problems. The laptop powers up, but never boots up fully, I cannot enter safe mode or system set-up. Also it says that the system BIOS...
The shadowing is an old technique. It means (if I remember correctly) that a copy of the BIOS and Video BIOS is stored on the RAM for quicker access. It should be nothing to worry about. The worst thing is that you dropped your laptop! I suspect that when you dropped it, you broke something internally. Without actually seeing the laptop, I cant tell you exactly what the problem is. I would try wiping the drive and reinstalling the OS. That should tell you if its the hard drive. (Although it is an unconventional way to find out). Also, depending on whats broken internally, it may or may not be salvageable, but it never hurts to try.
2helpful
2answers
My laptop shows me that the system Bios shadowed & video bios shadowed. And It saying ( entring Setup ...) but nothing happing and it stying like that. please help me
It is usually recomended that shadowing is disabled in the BIOs, so go to the setup Bios menu and select the default settings, press F10 and return.
Re boot and that should be that.
HOW DO I GET SOLUTION FOR BIOS SHADOWED
-BIOS shadowing is a feature of the system's BIOS. You can only enable or disable it from the BIOS setup screen.
-BIOS shadowing kinda like creates a copy of the BIOS to the system RAM for faster performance coz the RAM works faster than the BIOS ROM.
I have compaq presario f700, it displays ''system bios shadowed''. there is a tip to go to BIOS how can get to BIOS to disable/enable it?
At the Boot-up or while the cursor is at the top right corner of the screen (when you start your PC), press the F1 or F10 key (It's different for different motherboards for some it's Del)..disable system and video BIOS shadowing in the option.
Shadowing of BIOS just copies the BIOS code from ROM
to RAM during bootup for faster accessing...
You might want to try calling Compaq Customer Care for more help.I hope it helped.
My laptop beeds a restart, but i always get
It should also indicate which key to press to get into system configuration (usually Del, F1, or F2). Go through the settings and find "Shadow System BIOS" or something similar and set it to disabled.
BIOS Shadowing copies the system bios from ROM to RAM when the system starts, and is un-necessary in modern computers.
2answers
Hi there
If you go into the bios, you can disable/enable bios shadowing from there.
Good luck and thanks for using Fixya!!
4helpful
Bios shadowed
go to your bios setup...press delete key or f2 while the system is rebooting....in the bios...look for shadowing and disable it.
let us know,
Grand Canyon Tech
Grand Canyon Tech
