The problem started with the water not filling. i checked the hoses, cleaned screens and validated water pressure. There was nothing wrong there. I dug into the machine and started checking fault codes. There was only one (E54) which points to the inverter. Another piece of information is i have not seen the motor run since starting this investigation (it does move freely by hand).. Could a faulty inverter have anything to do with the water problem? I ask because i do not want to spend $220+ for an inverter and $60+ for a water valve in a 5 year old machine.
SOURCE: GE WCVH6800 front load washer
In order for the pressure switch to work it has to get pressure.
The switch is located near the top of the right side panel and can be seen by removing the top cover. There is a small pressure hose that leads to the switch and should be checked for crackes or chafing. There are three round sponges on this hose to keep it from rubbing on the moving parts. I had to replace mine after just over a year so I used a heaver hose with the same inner diameter. I used a 3/16 fuel line from Princess Auto and two new 3/8 stainless hose clamps.
SOURCE: you select cycle, the door locks, then unlocks
Check this posting for how to run a diagnostic test: http://www.fixya.com/support/t9576766-found_small_part
Test T02 will show you the most recently encountered codes. At the bottom of that posting is a link to the code definitions with problem resolutions: http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
SOURCE: Water won't fill the washer
Cool thing about these new computer controlled appliances is that they diagnose themselves. Easiest way to find issues is to run a diagnostic test: http://www.fixya.com/support/t9576766-found_small_part
Post back once you have the codes and we'll see about next steps.
If there are no error codes and you can't get any water to move, do "t08" and "t09" tests to check the valves.
SOURCE: My wcvh6800j1ms washer doesnt flow water when
Do a diagnostic test -- onboard computer can self-diagnose its own problems. Easiest way to find issues is to run one: http://www.fixya.com/support/t9576766-found_small_part
Post back once you have the codes and we'll see about next steps. If there are no error codes and you can't get any water to move, do "t08" and "t09" tests to check the valves.
(I am also posting the wiring diagram at the bottom, just for your reference)
The LF error means Long Fill.
When you start a cycle the water should come into the dispensers. If you have a good flow through the dispenser the valves will be okay.
I recommend checking the inlet water screens on the back of the washer. The inlet screens are located on the water valve. To access the screens you will turn the water off and remove the inlet hoses. The screens prevent debris from entering the valve and sometimes over time mineral deposits build up on the screens. This can block the water or slow the water fills down to a trickle. You can pull the screens out and clean them if necessary. Flush the inlets thoroughly with water when replacing the screens. If debris gets past the screens, it can cause the valves to stick open and an overflow of water can result.
While you have the fill hoses disconnected, place the ends of the hoses in a bucket and briefly turn on the faucets to check for proper water pressure and flow from both hoses.
A common reason for an L F (long fill) error on this washer is the drain hose being stuck to far down the drain standpipe.
If the drain hose is to far down the standpipe then a siphon can occur which causes the washer to fill and drain at the same time. This will cause a long fill error.
The technical details of this fault code are shown in the first image below. This information is valid for most Kenmore HE2+ washers. It is likely that it will apply to your model. If the washer is not filling with any water, check the water supply faucets behind the washer to make sure that they are properly open. If you are using a floodsafe device as shown in the second image on your water supply lines, I recommend replacing this device with normal water supply hoses. The floodsafe device will not work properly on most washers. Turn off the water supply faucets and remove the supply hoses from the connection on the back of the washer. Check the inlet screens on the back of the washer for debris or deposits that could prevent the washer from filling properly. Clean the screens if necessary and carefully replace them after flushing the inlet to the water valves thoroughly with water. (Failure to properly flush the inlet area could result in debris getting past the screens and fouling the inlet water valves.) While the water supply hoses are still disconnected from the back of the washer, place the ends of the hoses in a bucket and briefly turn on the water supply faucets to check the water pressure and flow from them. If the water supply is inadequate, you may need a plumber to resolve this problem. If the washer still won't fill after checking these issues, then you could have a failure in the solenoid water fill valves for the washer. You could also have a wiring failure or a problem with the electronic control board.
If the washer is filling, your problem would likely be in the water level pressure switch or the air pressure tube between the bottom of the tub and the pressure switch. A wiring failure or control board problem could also prevent the water level from being properly detected. To access the water level pressure switch, you can unplug the washer and remove the top panel. Screws at the very back of the top panel secure it to the washer. Remove these screws and then pull the top panel slightly back and then up and off the top of the washer. The water level pressure switch is normally on the rear of the right side panel of the washer. Check the air pressure hose and wiring connections. If no problems are found, you may need to replace this part.
