Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
Posted on Mar 01, 2009
Samsung HLN5065W shuts down in a minute
This started suddenly. Set will power on, make the chime sound, do it's normal powerup sequence and displays image for < a minute, then the lamp turns off, screen goes black.
The red TEMP signal shows on front. The set loses communication and has to be unplugged,
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
296
Points
2 tings, ,lamp fan motor stops or temp. sensor located on optical block activated
I bought a watch for my grandson. It had no instructions. It is from China MFG# FMDAW549. Are there directions available
Possibly these instructions:
http://forums.watchnet.com/index.php?t=tree&goto=110449&rid=0
DIGITAL WATCH USER INSTRUCTIONS May 27, 2006 - 05:59 PM On 5/26/2006 I bought from Walmart a $6.43 watch, on the back of which is written "AH 1175, 52, Battery CR2025, China Module, FMD, Base Metal Bezel, Stainless Steel Back, 100ft Water Resistant". It has no control buttons on top (where buttons may be accidentally pushed), the display is larger and more visible, and the color is dark, so I bought it even though I prefer models that have a fabric/velcro wrist-strap.
Four buttons on this watch are labelled: Light, Mode, Reset, and St/Sp. The instructions which I found inside its container refer to the Light button as A, the Mode button as B, the Reset button as C, and the Start/Stop button as D, but otherwise do not pertain to the watch, so I determined the button's functions by trial and error, as follows:
TO SELECT THE DISPLAY MODE
Push the Mode Button in order to select one of the following four display modes in the following order: Normal Time, Stop Watch, Alarm Reset, Time Reset.
In the Normal Time Mode, the Day of Week, the Hour, Minute and Second are displayed (none flash). If the Alarm and Hourly Chime icons are not displayed, the Alarm and Hourly Chime are turned off.
TO DISPLAY DAY OF WEEK, HOUR, MINUTE, SECOND AND WHETHER THE ALARM AND HOURLY CHIMES ARE ON:
Push the Mode button until no icon is flashing. The Alarm and Hourly Chimes are off if no Alarm or Chime icon is displayed beside the Second display.
TO DISPLAY THE DAY, MONTH AND DAY OF WEEK AND WHETHER THE ALARM AND HOURLY CHIMES ARE ON:
In Normal Time Mode, push the Start/Stop button. The Alarm and Hourly Chimes are off if no Alarm or Chime icon is displayed.
TO DISPLAY THE ALARM TIME
In Normal Time Mode, push the Reset button. The P or A beside the Alarm Time indicates PM or AM time. The P or A below the Alarm Time indicates a 12 hour clock; an H indicates a 24 hour clock.
TO STOP/START THE ALARM AND HOURLY CHIMES
In Normal Time Mode, hold the Start/Stop button down and push the Reset button (the Date and Day of Week will be displayed) to turn the preset Alarm and Hourly Chimes on, or off (to save the battery). To test the alarm, hold the Reset button down. The alarm and chimes are off when the alarm and chimes icons are not displayed.
TO STOP THE HOURLY CHIME
In Normal Time Mode, hold down the Reset button (the Alarm Time will be displayed) and push the Mode button until the Day of Week display is no longer highlighted; otherwise the hourly chime drains the battery.
TO SET THE TIME
To Fast/Forward until the correct number is displayed, hold the Start/Stop button down.
To set the Month of the Year, select the Time Reset Mode and push the Reset button until the Month of the Year number flashes; push the Start/Stop button until the correct Month of the Year is displayed and push the Reset Button.
To set the Day of Month, select the Time Reset Mode and push the Reset button until the Day of Month number flashes; push the Start/Stop button until the correct Day of Month is displayed and push the Reset Button.
To set the Day of Week, select the Time Reset Mode and push the Reset button until the Day of Week display flashes; push the Start/Stop button to until the correct Day of Week is displayed and push the Reset Button.
To set the Hour, select the Time Reset Mode and push the Reset button until the Hour number flashes; push the Start/Stop button until the correct Hour is displayed and push the Reset Button. For a 24 hour clock, push the reset button until an H is displayed. For a 12 hour clock, push the reset button until an A or P is displayed.
To set the Second, select the Time Reset Mode and push the Reset button until the Second number flashes. The Second number resets to Zero everytime the Start/Stop button is pushed. If the Start/Stop button is pushed as soon as the Second hand on your computer and watch are the same, the watch will be accurate to one second (to set your computer time to the second, log on to the Internet, right click on your PC's time display, select ADJUST DATE/TIME, INTERNET TIME, UPDATE NOW). The setting of the Second number will not be affected by setting the Minute number afterwards.
After the Second number is set, set the Minute number by selecting the Time Reset Mode and pushing the Reset button until the Minute number flashes; push the Start/Stop button until the correct Minute is displayed and push the Reset Button.
TO SET THE ALARM TIME AND TURN ON THE ALARM
Choose the Alarm Reset Mode. The alarm is turned on everytime the Alarm time is reset.
To select the Hour, push the Start/Stop button while the Hour is flashing and until the correct Hour is displayed, then push the Reset button (the Alarm and Hourly Chime icons will appear).
To select the Minute, push the Start/Stop button while the Minute is flashing and until the correct Minute is displayed, then push the Reset button.
Push the Mode button after the correct Alarm Time has been selected. The Alarm and Hourly Chime icons will be displayed beside the Second numbers.
The P icon indicates PM. The A icon indicates AM. The H icon indicates a 24 hour clock.
TO USE THE STOP WATCH
Choose the Stop Watch Mode. Push the Start/Stop button to begin the lap time. To pause the Stop Watch push the Start/Stop button to stop it and push it again to continue. To reset the Stop Watch to zero, stop the lap time by pushing the Start/Stop button, then push the Reset button (otherwise the Stop Watch will continue counting after other Modes are selected).
Apr 20, 2018 • Watches
2answers
Overheating
It probably has a fault.But try this.Disconnect all speakers and inputs and try again.If that works reconnect the speakers A PAIR AT a Time.That should lead to the fault.If that still shuts down.
the set is going into protection mode. This is caused when ever one of the many sections of the tv has a shorted circuit. The increase in current is detected by the protection circuit and it flies into action by turning OFF the ON relay.
Most often, but not always, it is either the high voltage section or one of the deflection amplifiers. But can be the power supply, the audio amplifier or voltage regulators, etc.
Goodluck..
1helpful
2answers
Tv turn off afterbeeing on for afew minutes
COULD BE THE LAMP IS BURNED OUT, COOLING FAN NOT WORKING, A BAD BALLAST OR BAD POWER SUPPLY. CALL 1-800-SAMSUNG FOR NEAREST SERVICE CENTER.
Hln5065wx xaa TV will turn on for few min. then shut off. After unpluging system for 30 sec. I plug back in it comes on for a bit then the color will start to go them shuts down.If I do this a couple of...
- Check the back cover "Switch cover" located bottom right. Make sure it is plugged in properly to the digital board (big silver case board".
- could also be sighns of the light or color wheel going. Lights at the front will let you know with flashing sequence.
Robge
1helpful
Samsung HLN5065W Lamp won't stay on.
Do you get any flashing lights?  Such as Lamp or Temp?  A common problem with these is the light not coming on.  Sounds like a temperature issue.  When you turn the TV on when it is cool, pull it forward and check the rear on the left to see if you can see the fan turning where the lamp is.
The light system is pretty straight forward:  Power Board -> Ballast -> Lamp.  It is controlled by the DLP Board, though.  Since it is powering up, it sounds like the Power Board and Ballast are okay.  The ballast is used to kick start the lamp on (similar to flourescent lights) but not during normal operation.
HL-R6768W not turning on. High pitch spin sound. Bad color wheel?
The high-pitched whine is definitely the color wheel.  The early color wheels had problems and many had to be replaced.  As part of the turn-on process, the TV checks for light and then checks for color wheel sync.  If the bearings are wearing out/dried out, it could cause issues with getting the proper color wheel sync, causing the set to not pass the turn on sequence.
Check Sears or partstore.com for a color wheel.  I like sears for experimental replacements since they allow easy returns.
BTW, mine is an early 61".  My color wheel was replaced when I had to replace my Light Engine.  My in-laws 50" was an early one and theirs went out within 2 years.
2answers
HLN4365W Start-up Issue
the main power supply may be getting weak. if so it will delay the time it takes it to come on and eventually it wont come on at all
Not Supported Mode
Sound as if the digital board has failed, Samsung p/n# Bp94-00385a
Bill
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
