Creative Labs Gigaworks S750 Computer Speakers Logo
Posted on Mar 23, 2013
Creative sbs 2.1 370 sub woffer no sound output how to check
4 Related Answers
hattonhall
Poppa Maddo
  • 372 Answers
  • Posted on Nov 04, 2011
SOURCE: Can i use AC Adaptor that has input: 230V-50Hz output: 9VDC to Creative SBS 2.1 370 Speaker?
Look at the label on the rear of the Creative SBS and make sure the 240v adapter you use matches what is stated there. eg. 9v d.c. 500ma
Provided the plug on the adapter fits in ok and the voltage is correct you must use an adapter with the minimum stated "ma" (milliamps). You can however use an adapter that has a greater "ma" capability....say up to 750ma, BUT you must not exceed the "v d.c." (DC voltage) rating.
Anonymous
  • 79 Answers
  • Posted on Jul 08, 2009
SOURCE: creative sbs 580: Does anyone know where I can
Are they USB speakers?
if not then.,,,, you know...
tbreeze47
Tom Carson
  • 3083 Answers
  • Posted on Nov 27, 2010
SOURCE: my creative lab t3100 does
I couldn't find anything on the setup, but a lot of reviews reveal that people are happy with this system, and are driving it with their computers, so there has to be a way. If the unit doesn't have sound, check the feed to it, and make sure it's a good cable, and also that it has sound.
I don't understand the last part, about the speaker feeding into the computer before the woofer, just doesn't make sense to me.
Check out the directions more closely, to see if they're erroneous and try to correct the mistake. You may need just a second look at the setup to figure it out.
Good luck, and hope this helps.
Anonymous
  • 121 Answers
  • Posted on May 30, 2011
SOURCE: my sound card driver has
Sound drivers are for the computer motherboard, you will not be able to find driver with SBS 230, as this is the model of the creative speakers you are using.\
If you are using a DELL, HP, Gateway or anyother brand of PC. Go to their website, e.g www.hp.com or www.dell.com.
Click on the drivers and softwares download section, type the model number or product number of your PC. You will find model number or product number on a sticker on the PC or the BIOS or the Invoice. Type the model number, the website will give you option to select the operating system, select the operating system you are using then click on Audio Driver, download and Install it.
Regards,
Shrey
Can I hook a Panasonic active subwoofer to a home stereo system and how may I do this ?
Your stereo system must have a sub woffer pre-out or sub woffer output.
No sound output
Replace audio out ic
easy to find
speakers connected to it
3answers
The Creative SBS 370 Works on 11.5V AC (IT IS NOT DC) 1600mA (Means 1.6 Ampere) and 18.4VA. So, the Power Adaptor which you connect to the power socket behind the woofer is an AC ADAPTOR and NOT A DC ACAPTOR.
1helpful
No I cant get my sub woffer to work woofer.There is power to the unit .I am trying to connest it to a sound bar which has a sub out.
If there is power to the woofer then a signal input must power the woofer to work. So feed a test signal or a audio siignal from a DVD and if there is no output then the AMPLIFIER section had faults.
Unless the sealed unit is opened it cannot be tested to confirm if the output , the input to the AMP or the power supply has failed.
Check if there is power to the output section to confirm.
2helpful
2answers
Creative SBS 2.1 370 Speaker - Volume Remote Controller not worki
Hi Arun!
Try to plug your speakers to an iPod or any MP3 Player to check if there's sound. If there is sound, then try plugging it to the green port at the back of your speakers.
If it doesn't have sounds then you need to buy a new speaker system.
^_^
Onkyo Subwoofer Pre Out Problem
May not necessarily be the out put, discontect the sub from the receiver and see if it still makes a hum, Making sure that you turn auto on, off on the sub woffer.
If it still makes a hum, then you have a earthing problem, you can get a earth filter put on your internal wiring in your home, or you can remove the earth pin on your sub woffer
1helpful
4answers
Problem about sound
i am using same configuration with 5.1 creative speaker with good sound. in 5.1 sound system there are 2 seperate jack for left and right speaker. you attach one adopter having 2 in and 1 out point.The jack is 'Y' shaped. that will solve ur problem.
Top Creative Labs Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
