Washing machine has f05 flashing on a hotpoint machine it wont pump out and cant get door open
The error F05 indicates that the pressure switch is jammed on full.
The only thing you can do your self is to check the filter is not blocked.
Remove lower rear panel of washer, locate and remove large black hose fatened to bottom of tub, watch out for water running out.
Remove and clean plastic filter inside hose.
Refit filter and hose, test for leaks.
If problem still persists, then could be faulty pressure switch or blockage in the pressure system.
Good Luck!!
Thanks
