Apple OS X 10.8 Mountain Lion Logo
A
Anonymous Posted on Mar 22, 2013
Os x 10.8 update - Apple OS X 10.8 Mountain Lion
peter schmitt
Level 2:
Sergeant:
  • Apple Expert 396 Answers
  • Posted on Jul 25, 2014
peter schmitt
Apple Expert
Level 2:
Sergeant:
Answers
396
Questions
Helped
62838
Points
660
Just go to software update in the apple drop down menu. Cannot update across platforms. Must be either 10.8 to 10.8.1 or 10.8.2 an so on but not from 10.5 to 10.6
1helpful
My i9900 canon has gone spontaneously from working fine to stubbornly "offline". I decided just to delete and reinstall it, but can't find the CD or its equivalent online. Any help please?
What OS do you have? Please add the update version for Windows 10. The drivers are still available from Canon here: https://www.usa.canon.com/internet/portal/us/home/support/details/printers/support-inkjet-printer/i-series/i9900?tab=drivers_downloads for supported OS versions. It looks like the printer used Windows Update for to install most of the drivers under Windows 7. There is an optional update for the driver on the site but it doesn't work unless Windows Update installed the basic driver. The Canon didn't officially support the printer for any OS after Windows 7.
The Windows 7 driver worked under 8 (8.1) and some versions of Windows 10 for a while. (Under Windows 8, the ZoomBrowser software didn't work.) Then Microsoft became strict about not allowing unsigned drivers to install. The easiest solution is to find an old Windows 7 computer to connect to the printer. Alternatively, get an unused install license and build a virtual machine to connect to the printer. Note: recent cumulative updates for Windows 10 have caused issues with USB printers.
If you are using Windows 8 or 8.1, try connecting the printer via the USB port with the machine off. The restart the computer; make sure that the Windows Update is set to find updates for other devices (not just Windows). If you are using the printer over a network, some found using the Canon ProMark 9000 series drivers worked.
I hope these ideas help. I wish that I had better news for you about Canon support.
(Building a virtual machine OS depends on your CPU allowing virtualization and free memory. You also need the Windows Pro or Enterprise versions of the OS for Hyper-V (Windows 10) or the Windows 8 VM equivalent. Third-party tools for creating a virtual machine may work on the home edition.)
2answers
My Toshiba Satellite P55W-C5316 had a Toshiba update made it crash. It only showed black screen. How can I keep computer from automatically updating Toshiba update?
go to setting and turn off automatic updates, I think toshiba has a program for their updates I think its called catalyst disable the updates there too
https://www.6ya.com/mr.mike good luck
3answers
How can I Fix Windows Update Error 80244022?
anything earlier than win will not update anymore as there is no microsoft support fro win 7 and win xp
3answers
What version of Linux runs on DL580 G4?
Minimum Supported Red Hat Updates •Red Hat Enterprise Linux 5 Update 1 •Red Hat Enterprise Linux 4 Update 5 6-Core/4-Core Intel Xeon Processor 7400 Series •Red Hat Enterprise Linux 5.22 •Red Hat Enterprise Linux 4.7 Minimum Supported Novell Service Packs•SUSE LINUX Enterprise Server 10 SP1•SUSE LINUX Enterprise Server 9 SP31 6-Core/4-Core Intel Xeon Processor 7400 Series •SUSE LINUX Enterprise Server 10 SP23 •SUSE LINUX Enterprise Server 9 SP44
I was instructed by Java to Run
Thank for contacting Fixya, I will be glad to assist you.
Here is the most current version for Java for Mac OS X 10.5.8 Leopard: Link: Java 10 for Mac OS X 10.5.8 Leopard
Please update me if you have any challenges with this Java update.
Thanks.
Regards,
"The MacTechTrainer"
Hello, I can't install my os it says the BIOS is not ACPI compliant. What to do?
Check the computer manufacturer's website for a flash BIOS update. ACPI is an onboard power management program that works with the OS to turn devices on the motherboard on and off as needed in order to conserve power. Modern OSs require this function to operate correctly. The update will come with instructions for installing it, and you must follow them exactly, else your computer may become unusable.
If no update is available, you'll have to revert to the original OS to use it, as there is no way around this that I've heard about. ACPI has been standard on PCs for over 10 years, and it's unlikely that any modern OS will work on a PC without it.
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
