I understand this was a big problem with the 40" several years ago. Evidently requires taking the set apart to tighten screws. TV goes black, then blue. Have to shut it down and restart after a minute. Problem reoccurs after a few minutes, then doesn't come back
SOURCE: Sparks are flying
This needs to be corrrected. The job of the waveguide cover is to protect the waveguide (opening) and the magnetron from buildup of food particles and grease. When the grease and food particles build up on and behind the cover, they will carbonize and arc - and maybe even flame up! The solution is to clean it and keep it clean - but if it's too dirty or is burned, it must be replaced. Sometimes it's necessary to remove the cover to clean both sides of it, and to clean the edges of the opening it covers. It is sometimes held in place with a small plastic rivet (or screw) and once that is removed, the cover will slide over a little then drop down. Be VERY careful not to get cut on the potentially sharp edges of the opening, and do not spray anything into the opening. Apply an alcohol-based cleaner (such as the purple kind) and /or gentle scouring powder to a cloth or paper towel and carefully wipe it out, then when it's dry, reinstall the cover and the rivet. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. If you or a friend decide to work on it, we have *critical* safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk Even better, we have the full service manual in PDF format available for download at http://207.234.249.73/mwd/r930ak_aw_sm.pdf It will guide you through the safety issues and give you exploded views and part numbers in case you need to order parts, which you can get at Tritronics at http://www.wehaveparts.com
SOURCE: Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
SOURCE: sharp aquos lc-52se94u green screen
If it it new, take it back. The product is not working properly.
SOURCE: Picture goes black but hear the sound
this is the problem related to display of ur TV screen...please contact the service centre...plz dont try to repair it urself..
SOURCE: I have a Sharp LC-37SH20U flat screen TV. The
The main video backlight board is dead,must be replaced.
