SOURCE: LG Privilege GR-726R: ice buildup
There is only one screw and then you just pull it out. Remove all the shelving first.
Sgt 48
SOURCE: Bottom Freezer has ice built up
Possibly the defrost element is faulty, this is located behind a cover in the back of the freezer compartment and is attached to the fins of the evaporator. It also has a defrost limit thermostat which could also be the problem. I presume that the fan is working after you have defrosted the unit?
SOURCE: Ice dispensor
Make sure that the "flapper-door" closes about 3 seconds after the ice dispenser button is released. Mine had a habit of catching and staying OPEN. This allows warm air to enter the dispenser / freezer compartment causing your problem.
If it is stuck you have to take the dispenser apart to loosen / lubricate the flapper door cam to allow for free movement.
This is the worst ICE system I've ever seen for a variety of reasons.
SOURCE: why is there heavy ice
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
