I just made my new desktop with a UD3H and got everything to work besides my audio input. The headset is a razer carcharias and its been working on my laptop no problem but when I plugged it into my desktop I can hear out of my headphones put when I try and listen to my mic it is just making a humming noise. I have tried both front and back jacks and had no luck. I am stuck on what to do with and was hoping to get a solution. Thank you for your time
SOURCE: mic not working when headphone plugged in
Try changing the Windows Default Audio devices
Hopefully this will work
SOURCE: audio input/output problem
Dear user,,
Pl go to control panel and select sound/audio device and click and see you see install sound device.
pl double click on speaker symbol at taskbar.
see volume controler and selecting hedphone device and see it is mute or not
Regards,
Ravindra Shah
SOURCE: audio/sound problems
sounds (pun intended) like you have your headphones plugged into the microphone input. See if you can change the spot they are plugged in...
good luck
SOURCE: No audio output to tv on my dell 1545
That, & most, earphone sockets, simply doesn't have enough "Current" or signal voltage to drive your TV set's audio in Amplifier. You need to get a Pre-Amp, to amplify the signal, up to a level that can be used by the TV. So you need to purchase, or build from a kit, a small stereo pre-amp and insert it between your laptop & TV audio In.
Testimonial: "Thank you for the response - will try this and see if it works"
SOURCE: My Razer Carcharias headset's sound in the
replace the jack that plugs into your player. it has an open in it
