Angela, Menu, Settings, Language & keyboard, Touch Input, Text Input, under Finger touch precision, choose Calibration tool or even Reset calibration.
If you have the app, yes you can calibrate touch screen.
Try links below for more info.
Try setting the wire up in a certain way like bending it or but a bottle cap under the wire and then put like a book on top of the wire after the bottle cap.
may be your charging port of tablet pc be faulty or gets dirt inside , go to any nearby electronic repair shops and get it repaired if u cant fix it on ur own.
Whoever used the term "calibrating an iPad" may have been referring to touch screen calibration.
Some touch screens need to be adjusted, or "calibrated", or the device may act as if you touched a different spot on the screen than you did. The iPad screen does not need to be calibrated. If the iPad make a mistake about what spot you touched, the error may be due to:
a defect or damage;
a screen protector;
a cold finger;
a hand that is holding the iPad and inadvertently touching the screen;
a finger that is inadvertently touching the screen.
