Question about Peavey SP2 PA Passive Speaker
Peavey ecs-1000 schematics want to unhook speaker to repair
2 Suggested Answers
6ya staff
SOURCE:
djlaplaya
dj LaPlaya
  • 74 Answers
SOURCE: are peavey pv 2600power amps loud
yes, that would be very loud.
Posted on May 06, 2010
Can you repair a tear in a peavey guitar amp and will it affect the sound
I have to assume you're really meaning a tear in the speaker cone. If so, yes you can repair it if it's small and yes, it will affect the sound. Peavey Bandit amps have come with a few different speakers over the life of the name, but all will still be available either online or directly from Peavey's parts department. Here's the link-
http://www.peavey.com/support/contactinfo
Oct 21, 2015 | Peavey Bandit 112 80W, 12" TransTube Combo...
I need schematic Peavey KB5 for repair
Peavey com contact peavey directly and they'll send it to you.
Jun 18, 2015 | Peavey Music
Ddt speaker protection lights up and speakers cut out Volume is bareley on
shorted output, triac, or shorted speaker cable, shorted speaker, crossover...unhook speaker cables and see if it stops, if not, shop time.
Sep 08, 2013 | Peavey Music
Peavey PR15D amplifier board. What is the part number of U5. The IC is damaged and can only read the beginning of the part #. Starts with HC.....
You can contact Peavey and they will send you the schematics. If you can tell me a few characters of what is on the chip I might be able to give you a clue. For power amps they often use the LM3886, an eleven lead power amp clamps to a heat sink. For typical small 8 lead op amps the often use 4560's.
Mar 22, 2011 | Peavey Electronics Peavey PR15D 15" 200...
No output from channel B. Slight crackling, but not a dirty potentiometer. A dry joint or easy fix?
Start out by doing some simple troubleshooting yourself. You have one working channel so substitute the cables from the working channel to the nonworking channel to see if you have a cable problem.Check to see what button settings you have on the amp. One might have been changed by accident. I am assuming your are wired up for stereo and not mono.. Here is a link to the manual if you don't have one:http://www.peavey.com/assets/literature/manuals/80300573.pdf I should also have mentioned to substitute the speakers from the nonworking side to the working side to make sure you don't have a speaker problem. Notice in the manual that it states that the DDT compression switch should be enabled at all times to protect your speakers. Also take note of page 3 Operation notes for both the thermal protection and the DDT circuits. Amplifier failure is usually caused by the failure of another component most often cables and speakers. If a dead short (broken cable or blown speaker) is presented to the amp it may fail no matter how good the protection circuitry is. If the simple tests I mentioned don't help I recommend taking it to a Peavey dealer with a good service shop as they will have access to Peaveys direct replacement parts. The schematic can be obtained but for a proper repair the direct replacement parts should be used. Peavey was one of the brands I serviced when I was still working as the service person for a music store. My eyesight has deteriorated so I am semiretired. Hope this advice helps.
Oct 23, 2010 | Peavey Pv 2600 Power Amplifier
Circuit diagram for a Peavey 130 special
Try http://www.peavey.com/support/contactinfo/ You may be able to get one from them. When I was doing repairs they would only release schematics to Peavey dealers but you can always ask.
Jun 24, 2009 | Peavey Pv 2600 Power Amplifier
Peavey SP2 PA Passive Speaker Logo
42 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
PNiss
Are you a Peavey Music Expert? Answer questions, earn points and help others
