Re install the software, or use the Windows Wireless Utility. Take a look at Belkin Support page: http://www.belkin.com/us/support-article?rnId=6915
SOURCE: Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
SOURCE: Belkin N1 router doesn't want to work...
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Configuring
router for Cable Internet
To
configure your router for Cable you will need to set your router's WAN
(INTERNET) port to 'Dynamic IP' (DHCP) option. The router is set to this option
by default.
Configuration steps:
Step 1 Connect the cable modem to the WAN (INTERNET) port of your
router. If the modem has USB connection make sure that it is NOT connected to
any computers via the USB cable and that the modem is switched to Ethernet (not
USB). Only the modem's Ethernet port should be connected to the router's WAN
(INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to
it wirelessly.
Step 2 Open your Internet Explorer and log into your router by typing in
its IP address (in most cases the default IP is http://192.168.2.1 ). Note that you do not have to be on the
Internet in order to access this address because you are just connecting to
your router's address. Specify username and password for your router, default
is `admin' and password is password.
Step 3 After logging into the router select Setup. Set Internet
Connection to 'Dynamic IP (DHCP)' option.
Step 4 Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the
new configuration.
If you are having difficulties accessing the Internet, you need to:
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this
from the computer which the cable modem was directly connected the last
time. This will place the MAC address of your computer into the router. Save
settings and reboot the router. Reboot your cable modem as well.
- Log into the router and go to Status page. Note what IP address it is getting
on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET)
appears to be in the same range you are using on your network (e.g.
192.168.2.x), you will need to change the range you are using on your LAN to
something different, e.g. 192.168.88.x. You can do this on your router under
Setup > LAN Setup. Note that after changing the IP of your router you will
only be able to access it through its new IP, e.g. 192.168.88.1.
- Uninstall your antivirus/firewall software (sometimes disabling or closing
the software is not enough) and reboot your PC. After establishing the Internet
connection through the router, reinstall your antivirus/firewall software.
SOURCE: trying install belkin n150 router.setup router and
Try the following:
1. Make sure your PC is connected to the router directly and the LAN ports are lighting up
2. Reset the router
3. Reset the network adapter on your PC (or just restart the PC)
This should ensure that you are connecting on the LAN port.
SOURCE: My belkin N router flashes amber on my modem...all the time.
You may need to upgrade the firmware of the device. Please see setp by step instructions here: http://en-us-support.belkin.com/app/answers/detail/a_id/497/q/routers
Download your latest firmware from: http://en-us-support.belkin.com/app/answers/detail/a_id/306/kw/F5D8236-4/r_id/166
SOURCE: Belkin router won't accept PIN on new computer
Hi Friend,
You need to just disable one of the option in the router,please follow the below steps
1.Type 192.168.2.1,in the Internet explorer,You will get a belkin router setup page
2.on your left hand side click on Wifi Protected Setup(WPS),it will asks for password,leave it blank and click on submit
3.It will say WPS enable,change it to disable and click on Apply Changes
4.Now try to scan and connect to the wireless networks
Regards,
Ayyasam
Retrieval Steps
