Once in a while, our television will not turn on, and below the green light, a red flashing light will appear. This light flashes continuously. To fix this, we turn off the tv and turn it back on, and the tv will work like normal. Is there a part we can replace? Any details will be greatly appreciated.
SOURCE: 6 red blinks wont turn on sony rear lcd projection
thermal fuse. it sits below the lamp and has popped. replace with new fuse or just short (eliminating fire protection) let me know if you need instructions.
SOURCE: Problem with Sony Wega 50 in kdf-50we655 light blinks 55 times
Symptom shows that TV needs Lamp replacement.
Sony TV Lamp is available in Part Store and lamp replacement procedure is written in user manual of TV.
SOURCE: I have a SONY LCD TV model KDF 50WE655 w/ Blue Dots on screen :(
The blue dots are cause by a defective optical light engine. This parts is quite expensive.
Read the info from this link for more info.
SOURCE: My Sony Wega model KDF-50WE655 LCD projection T.V
CK the lFan that keeps Lamp cool if it is bad lamp will not fire..
SOURCE: How do I replace the lamp in my sony lcd
TV has 2 thumb screws on lower corners, loose these screws and take off lower front part, there is lamp cover under that removed lower long part at TV front, remove lamp cover, lamp is in front of you, lose its screws and pull it out.
Slide new lamp and put things in reverse order, job is done.
Lamp replacement procedure is also mentioned in User Manual of TV and if you want to download copy, click Sony Support.
Thanks.
