After brewing coffee the unit continues to drip from the spray head. Also it does not use all the water so the pot of coffee is short. I have removed the top and the washer I can see under the plunger appears to be in good shape. I use filtered reverse osmosis water so the is no lime build up. I have cleaned it anyway, with no change in problem.
SOURCE: Bunn Coffee Pot Leaks Water
I obtained Bunn washer seal repair kit from buy-it-now-store.com for $6 plus $7 S&H and it solved the problem.
SOURCE: bacon grease in my bunn coffee pot
Did you let the vinegar mix with the hot water in the tank for 2 hours? If this didn't fix the problem, please call 800-352-2866 with the model and date code and we will be happy to assist you with this problem.
SOURCE: My NHB bunns coffee maker
If you will call Customer Service at 800-352-2866 with the model and code date, we will be able to help you resolve this issue.
SOURCE: My Bunn NHB makes a continuous
Check with Bunn and see if there has been a recall. I did in Canada and they sent me a new machine complete with some Tim Horton's coffee! http://www.bunn.com/
Good Luck!
