SOURCE: pin out guide for gigabyte g41m
The user manual for the motherboard is available on the gigabyte website.
This has the layout of the circuits on the motherboard.
http://america.giga-byte.com/FileList/Manual/motherboard_manual_ga-g41m-es2l_1.1_e.pdf
Not sure if this is what you are after. If it is the pcb circuit board component wiring diagram you are after then please clarity.
SOURCE: i am trying to connect the front side usb on my
Get the manual here:
http://www.gigabyte.com/support-downloads/download-center.aspx?kw=GA-G41M
You need to install the motherboard's chipset driver and then the latest driver for the graphics card.
SOURCE: how to update bios on mobo g41m-combo
Upgrading your BIOS Now lets go through the various procedures needed to update your motherboards BIOS. First you need to find out if there is a BIOS update available for your motherboard model, and if there is, whether you need it. Before we go searching for that information, you will need to locate your motherboard model number/name. This can be done by looking at the documentation that came with your system, or even just by opening up the case and looking for the name silk screened onto the motherboard. If you have a system that was built by a major manufacturer, such as Dell or IBM, look on the manufacturers website under your systems name or number to find updates. If your computer was assembled by a smaller manufacturer, look for the motherboard manual to identify it. If this fails, use a program like Sisoft's Sandra to identify your motherboard model and manufacturer. To determine your motherboard make and model through Sandra first down load and install the program. Start up Sandra and double click mainboard information. Once you have your motherboard manufacturer name and model, its time to find your motherboard's model, current BIOS revision and look up what newer BIOS revisions are available. hope this helps
This should give you both the manufacturers name, and the model number of your motherboard. Note down that information.
There are two ways to do this, the first through the manufacturers automatic BIOS update software, and the second by searching through the manufacturers website support section.
