Need the remote code to program a universal remote
043,076,084,012,000 are the codes to check. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
SOURCE: A/V Mode
Only way that might work is change channel up / down less than 2 or greater than 99 ....see if
Video appears.If not, search for remote for your model on www................HTH.......T.
SOURCE: I lost Orion 13" Model TV1318 remote.Need to menu button access
you can purchase a advanced universal remote or you can go through the menu manually on your set
SOURCE: A/V Mode
I HAVE A 19 inch tv Orion MY DVD manual says I need a input remote so the unit can work
SOURCE: I have an Orion tv that is model #TVCR1021A and I
i have three orion codes. 0115 , 0713 , 0105 . Did these help ?
