No heat, light or fan. It tripped the domestic circuit breaker when it failed. But the top oven still works.
SOURCE: Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
SOURCE: neff u1421 bottom oven fan is working t/stat
Can only be either element or thermostat. I suggest you check element and connections
SOURCE: Neff u1421 bottom oven: Either fan works but no
You need to replace the oven fan element, as there is probably a seperate element in use when used on convection heat.
Please rate my solution.
Thanks.
