Televison & Video Logo
Fareed Ali Posted on Mar 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony Trinitron Model KV20FV10- when I turn it on the Sound comes on BUT no picture and the red light for the Standby Times keeps flashing non-stop.
In addition to no picture (sound only) I cannot activate the menu on the remote
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Mar 22, 2013
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15005594
Points
237762
How many times do this standby light blinks. It is fault indications. You can get an idea about the faulty section inside the TV, by counting these blinks occurs at one time switch ON. These are called blinking codes. For more details about blinking codes to Sony brand TVs, check this link. Pull up older posts there. Surf the site with patience.
5 Related Answers
rajanshyam
  • 11 Answers
  • Posted on Aug 31, 2008
SOURCE: sony trinitron wega 36 inch
If you are not a professional Electronics guy,it is beyond you to tackle this problem. otherwise log on to www.free service manuals.com and see the SONY Blink codes and also download the service manual.best of luck
Anonymous
  • 252 Answers
  • Posted on Oct 14, 2008
SOURCE: Sony Trinitron KV-24FS100 red light flashes 4 times
your tv had a problem.if you have a knowledge in electronics, check or replace the horizontal transistor beside the plyback. it is a black square parts with 3 pins.
Anthony Gonzales
  • 267 Answers
  • Posted on Jan 22, 2009
SOURCE: blinking Sony Trinitron with no picture or sound
you have a drive ic problem. ic 600, r640 and modification needs to be performed. Take to a Sony servicer. Est.$150 parts and labor
Anonymous
  • Posted on May 15, 2009
SOURCE: sony tv model # kv36fs320 no picture sound is
check power supply. measure crt voltage on crt pcb at the tube nack.
Anonymous
  • 563 Answers
  • Posted on Jul 11, 2009
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
4helpful
2answers
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
No picture or sound when powered up. Red Standby light flashes continually. My Sony KV 36 XBR250 Wega Trinitron XBR is about 10 years old and has worked perfectly up to this point. What could be the...
Did you get your set fixed or did you replace it? My same set did the same thing. Turned it off for 2-3hrs after watching it and when I tried to power it up- nothing but the sound it would normally make just before the major power up, sort of a relay click sound. No picture or sound but the red light blinks non-stop.
2helpful
3answers
Kv-32fs16, no picture or sound , red lights flash 4 times
Hi
In sony tv`s the 4 blink code(sony error codes)usually means that there is a vertical deflection problem.
It is often caused by a faulty vertical output i.c and/or related components. If you feel handy with a soldering iron let me know and i`ll help you with it.
Hope this help Merry Christmas
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
2helpful
Sony Trinitron KV-28LS36U no sound or picture, the standby light flashing green and red but if i switch it on a little bit of sound comes and then switches off. how can i repair?
The unit is shutting itself down because a problem was detected internally. When this happens, the standby light should blink a repeated pattern. Please count the number of blinks and post the number here. That will indicate the circuit in which the problem occurred.
Thanks,
Dan
Sony Trinitron KV-32FS12
i think your tv had a lose contact or crack on board
Sony trinitron wega 36 inch
28helpful
5answers
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
152helpful
14answers
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
