I have a new telephoto lens and when i try tk take a photo the camera is not storing it
SOURCE: "Lens not attached" warning when lens is in fact attached.
Hello. Check the area around the lens mount carefully - specifically the contacts. Make sure all are clean and protruding the same. If one is lower than the rest, try 'flicking' it with a fingernail (lightly) to see if it will pop up to the height of the others. It may have dirt or a particle of dust lodged. If this doesn't help, get the lens to Nikon for a check-up.
SOURCE: Nikon Coolpix L11 camera
FIND THE USB OPTION IN YOUR CAMERA MENU AND SELECT MASS STORAGE OPTION, THAT WILL ALLOW YOU TO CONNECT & VIEW THE PHOTOS LIKE A REMOVABLE HARD DRIVE OR JUMP DRIVE
SOURCE: r05 problem using d70, camera will not take a photo in autofocus
It is actually an error message generated by your compact flash and means that the card is no longer readable. A lot of D70 owners have reported this error without being able to find another solution other than reinserting the card or changing the card to a different brand. You could also try cleaning out the memory card slot and check to see that all pins are aligned and not bent.
Good Luck,
Jeff
SOURCE: blurred action photos
Turn of the high quality mode to low quality mode... pictures will be clearer.
