Make sure the paper type is appropriate
Clean the printhead
Align the printer using the control panel
--Touch the Tools icon on the touch screen.
--Touch Tools .
--Touch Align Printer .
When the alignment is complete, the product prints a test page and the control panel displays a message indicating whether or not the alignment was successful.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
SOURCE: inccorect cartrigde
Go to this link, download file and follow instructions, it worked for mehttp://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=227:5:0:570:0:0&framed=&docid=ENUS25374&relevance=1
SOURCE: How do I change the ink cartridge on lexmark x3480
Please use lexmark solution center... here it is:
To install a cartridge using the Solution Center:
Thank you......
SOURCE: Lexmark x3480 cartrige incorrect message
I had the same problem. Downloading and running the patch program solved it for me. Follow the link below!
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:570:0:0&docid=ENUS25374
Regards Robin
SOURCE: alignment of cartridges
To align the cartridge from the control panel:
Please follow the steps given below:
1. Please Load a plain paper.
2. Press and hold the "Scan" button for three seconds.
3. An alignment page prints.
4. Place the alignment page onto the scanner glass.
5. Press the "Scan" button.
6. Once scanning is complete, the cartridge has been aligned for optimal print quality. Alignment must be complete before continuing with any print jobs.
SOURCE: alignment issues put in new ink cartridge
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
1.
Make sure the printer is on.
2.
Open the printer cover. The print cartridge carrier moves and stops at the
loading position, unless the All-in-One is busy.
Note: If
the carrier does not automatically move to the center, turn off the
printer/unplug the printer from the power source and then slide the carrier to
the center.
3.
Remove both cartridges from the carrier.
4.
Close the printer cover.
5.
Rebrick (pull out the power supply, black box where
the power cord is plugged in at the back of the printer, and put it back after
30 seconds).
6.
When the printer turns on, reinsert one cartridge first.
7.
Close the printer cover and check for any errors.
8.
If no error appears, reinsert the other cartridge. Close the printer cover.
9.
Replace whichever cartridge is causing the error to appear with a new
cartridge.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
