Navigon 2100 Portable GPS Receiver Logo
A
Anonymous Posted on Mar 21, 2013
Navigon 2100 software won't start - Navigon 2100 Portable GPS Receiver
5 Related Answers
Anonymous
  • 379 Answers
  • Posted on Dec 27, 2008
SOURCE: need a navigon 2100 user manual
http://www.navigonusa.com/_pdf/manual/Manual_2100_2120_English.pdf
this is your manual .
Anonymous
  • 532 Answers
  • Posted on Mar 23, 2010
SOURCE: Navigon 2100 screen problem
When you changed your charger, did you get the right one?
I bought an iGo and thought I could use the standard min usb tip. However, tip number A53 does charge and show the map.
I hope this answers your question.
Anonymous
  • 676 Answers
  • Posted on Jun 14, 2010
SOURCE: looking for a motorcycle mount for my navigon 2100
The following web site will be able to help you out. They have several kinds. It depends which one you want. Being a Harley you probably want the chrome. Good Luck and please rate.http://www.gpscity.com/search/q=motorcycle
Testimonial: "Extremely helpful and much appreciated ! Thank you !!"
chemmoo
  • 9 Answers
  • Posted on Jan 19, 2011
SOURCE: Navigon 2100 displays the computer symbol when connected to charg
Wiring diagram pinout for Navigon GPS charge and concurrent use Pin Pin
Name Description 1 +5V 5 Volts Direct Current 2 Data floating/Not connected 3 Data floating/Not connected X Ident Conneted to Pin 4 (GND) as pure short, no resistor 4 Ground Ground, shorted to pin "X" Use of standard mini-b will place unit in Data Exchange/Synchronization mode. Use of mini-b with a 4-x pure short will allow use of Navigation software and concurrent charging. USB power source must be 1000 ma or above.
Anonymous
  • Posted on Jul 04, 2011
SOURCE: My Navigon 2100 GPS lights
I HAVE A 2100 NAVIGON GPS SCREEN WONT COME ON TRYED CHARGEING IT THE ORANGE LITE COMES ON /WONT CHANGE TO GREEN ALSO TRYED TO RESET NOTHING DO YOU HAVE ANY IDEAS WHAT ISHOULD DO NEXT .
1helpful
Fs201
I would suggest going here and reading about your unit.
http://reviews.cnet.com/car-gps-navigation/navigon-2100/4505-3430_7-32744602.html#reviewPage1
Go through the 2 pages.
Good luck
My Navigon 2100 GPS lights like it's charging, but it won't turn on
1helpful
Navigon 2100 car charger unscrewed. Found a few
[PDF] NAVIGON 2100/2120 User's Guide Your NAVIGON 2100/2120 comes with the following accessories. .... With the NAVIGON 2100/2120, you can also use an external GPS antenna (not pro- ...
support.navigonusa THEIRS A SITE FOR YOU YOUR FUSE IS A 6V 1 A RADIO SHACK SHOULD HAVE ONE OR PACK OF 5 6 BUCK OR SO
4helpful
The MN6.exe fatal Application error is displayed all the time and I am unable to use the Navigon 2100 GPS
push the reset button on the side of the system (a paperclip works well for this). Also, remove the card and put in again. If this doesn't work go to Navigons website and make sure you've downloaded all the software updates. Make sure your unit is fully charged as well. Don't waste your time emailing Navigon's CS online help....I attempted to contact them on 3 separate occassions and never got a response. Good luck. Hope one of my work-arounds helps you.
1helpful
Want to install xcsoar on a navigon 4310 pna. put the xcsoar program on a micro sd card, can't get it to work.
Hi Mart136,
Were you able to get XCSoar to work on your Navigon 4310? I have the same problem with XCSoar and my Navigon 2100 Max. I did exactly as prescribed for installation on the XCSoar site but my 2100 Max keeps asking for the Navigon SD card .. it doesn't want to recognize a standard SD card.
Does anybody have any suggestions? Thx Much!
Need users manual for navigon 2100
we purchased a used navigon 2100 it did not have a user manual with it and we would like to have one
1helpful
Screen stuck
Had same problem with a navigon 2100 and after trying my daughters car charger it worked properly. Called Navigon and they are sending me a new car charger.
Navigon 2100 text to speech not working
the same happened to my 2100 3.5 inch. any remediatons?
Top Navigon GPS Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Navigon GPS Expert? Answer questions, earn points and help others
