My router was yesterday I noticed that the working fine a week ago, then when i started playing WLAN light on my Dl-524UP Wireless router isn't even on. I can't connect wirelessly to the internet from my other computer like before. All of the other lights are normal and everything IS plugged into the right spot. I CAN connect to the internet from one computer, which is plugged into the router via a cable, but not wirelessly from the other.
I have tried reseting the router, and checked all the settings and I had no luck. The Wireless USB reciever on the other computer IS connected properly, and running well. But it cannot recieve any signals from the router.
SOURCE: Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
SOURCE: di-524 dlink; wireless laptop connects but no internet or network
Your wireless card is dead, replace.
SOURCE: D-Link DI-534 Starting up problems
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
SOURCE: After replacing Cable Modem, D-Link DI-524 Wireless will not work
Hi Serina - first of all: what a great post! Very detailed and professional. I just have to say that, since I'm reading here lots of "interesting" questions sometimes.
To your problem:
Apparenatly the router does the "routing" part well, since you can access the internet via cable. The problem is the wireless access point.
Your IP output looks actually good - I can't see any problems with the values. What I would try to do is to disable IPv6, since it is only used on your internal LAN and not yet implemented on the WAN side. This page (link) has a good write-up on the how-to. Don't do the registry part - just disable it in the Properties window.
I had noticed conflicts on computers where IPv4 and v6 were installed simultaniously.
Try it and see if that corrects the problem. If it does not, please let me know.If you have any more questions, just come back here and leave a comment - I'm happy to help.
