How to remove rear axle from 2004 ba ford falcon
Hi there.
Well first jack up the rear end of car then block up the front wheels (front and rear) and put stands under the rear jacking points STILL keeping the pressure on the jack, clamp the rear brake pipe that comes from the body to the rear axle and clamp with a small clamp
but dont tighten to tight remove the flex pipe and also the rear shockers from the axle ,then the spring u bolts and then the hand brake cable from the center adjuster,now it should only leave your tail shaft 4 nuts/bolts.
But why are you removing the rear/axle????
Hi Leanne McKie, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
