SOURCE: Kitchenaid KHMS155LSS 1000 watt microwave makes grinding noise
Chances are you have a bad stirrer motor or the stirrer blade is jamming or loose on the motor shaft.
Your owner's manual should tell you how to remove the stirrer cover to check it.
If
for some reason you don't have your owner's manual, you can download it free here, as well as the parts manual for your model.
You can also find
helpful exploded view diagrams and order parts by entering your full
model number here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: Kitchenaide KHMS155LSS Microwave F2 apears on
"F2" means your membrane keypad is shorting.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door
open when it's not in use, and of course, never leave an oven cooking
unattended.
You can order the control panel frame assembly with a keypad already installed here
You can also find handy exploded views there. Just do a search by full your model number (KHMS155LSS1, KHMS155LSS2, KHMS155LSS3, KHMS155LSS4, etc.).
You first unplug the oven and remove your control panel assembly as per the video at
our site.
Then disconnect the keypad strip as per the picture below.
Then you take out the screws holding your circuit board to the old frame and put it in your new frame
Be careful, since the display is glass.
Reassembly is the reverse of disassembly.
We're
SOURCE: microwave model KHMS155LSS-3 turns self on
I had the same problem with the same model of KitchenAid Microwave. KitchenAid customer service will act like they never heard of the problem, although if you google it, you will find that this is a very common problem. Ask to be transferred to the safety department. After more than 6 months of complaining and several repair attempts (they replaced control panel and switches), KitchenAid finally gave me a full refund. This is a serious safety defect for which they have no fix. The product needs to be recalled, and I am willing to testify that KitchenAid was criminally negligent when this product finally causes a house fire and possibly serious injury or death.
SOURCE: Accidentally ran my KHMS155LSS-1 KitchenAid
If the unit quit working while cooking then your not in a good situation.
There are 3 fuses/cut off thermostats inside the unit that if they
break when in use--means something else caused them to break and you
have another problem.
You will have to pull the unit completely
down and then take off the outer case of the unit to look inside. The
most common fuse that breaks is located just behind the control panel
and it's a 1" long ceramic cylinder fuse. If it has no continuity then
get another and see what happens when you start the cycle.
I
should warn you that microwaves are the one appliance not recommended
for do-it-yourselfers because they store a charge in the capacitor and
if not handled correctly and you touch the wrong wire it can actually
KILL you.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
