Model name 20023 S/N: CB05482134 MO: CB00121538
SOURCE: LENOVO G550 model 20023 DRIVER
The same model Lenovocan have different types of network, video and audio drivers and unless youknow exactly which one is installed in your Lenovo, you need to download allthe drivers and install each driver until you find the right driver. When you download thedrivers, write down the device driver and it's file name so you have a recordof which driver you are installing and which directory the unzipped files arelocated on your hard drive. Go to the IBM/Lenovo WEBsite - support/download page and download the latest Windows XP devicedrivers for your model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true You can download thevarious drivers and then you click on and run the various driver files, theywill then unzip and expand into a sub folder on C:\drivers Then install thevarious drivers from this folder (run the set-up file).
SOURCE: When I am starting my
This blue screen gave me lots of trouble in the past. Then someone gave me some suggestions to prevent.
1) Clean your RAM.
2) Check your data cable of the Hard Disk. I recommend you to change the data cable and try installing windows Xp.
3) If again same problem comes then delete the partitions and again remake it, then format Hard Disk.
Hope this would work.
SOURCE: lenovo 20023 camer not found/driver instal
Just go to the link below and select your operating system and then the webcam driver:
http://consumersupport.lenovo.com/ot/en/driversdownloads/drivers_list.aspx?categoryid=600154
