Canon PIXMA  MP530 All-In-One InkJet Printer Logo
A
Anonymous Posted on Mar 19, 2013
How to disassemble MP530 CANON - Canon PIXMA MP530 All-In-One InkJet Printer
What does the print head look like in the Canon MP530?
The print head is what's connected to the drive belt. It requires a lot of printer disassembly to get to. Check you tube for a video in how to change it.
Canon mp530 one twain
All of the drivers, software, and utilities are available at the official Canon website. The link is attached below. Canon Support Drivers PIXMA MP530
2answers
Can you do macs? how do i print duplex with this printer, duplex is suported by my mac
The Canon-supplied MP530 driver doesn't have duplex printing as a print option. Mac OS 10.5 has Gutenprint drivers built-in for a number of popular printers, including the Canon MP500 which is a near match for the MP530 and includes the two-sided option for printing.
With the MP530 plugged into your Mac (or, presumably, available over the network) go to the Add Printer wizard ( System Preferences > Print & Fax > + ). Pick MP530, name the printer something like "MP530 Gutenprint" and under "Print Using:" choose "Select a driver to use...", select "Canon PIXMA MP500 - Gutenprint v5.1.3" and then Add the printer.
The MP500 Gutenprint driver isn't a perfect substitute for the MP530 one, however, so you should do this in addition to installing the proper MP530 driver from the Canon website and adding the printer using that driver with a name like just "MP530" or "MP530 Canon". In a year or two of using the Gutenprint driver I've only once had a print job that wouldn't render correctly (some missing lines on the printout), and for that one time I had to switch to the Canon-supplied driver to get it to work. All the other times I find it very convenient to have two-sided printing available as an option.
The two sided printing isn't particularly fast, but it's a whole lot more convenient than manually printing the odd pages and then the even pages.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Canon PIXMA MP530 All-In-One InkJet Printer Canon mp530 error 6a00
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
Clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like
1helpful
Hello
Unfortunitly this is not an easy fix. IF you still have under warranty you can contact Canon and they will fix it. If its not under warranty they can refer you to the nearest Canon Service center.
The 6A00 error is an internal error which can be caused by one of the following things.
- Sheet feed unit - Logic board - Purge unit
Good Luck
4helpful
2answers
How to disassemble the canon pixma ip4500?
http://pdfdatabase.com/download/can-ip4500-pdf-364791.html
http://www.retrevo.com/support/Canon-iP4500-Printers-manual/id/3124ci169/t/2/
http://rapidshare.com/.../canon_pixma_ix5000_ix4000_service_manual.rar
Get the service manual it shows all.
tricks-collections.com/reset-printer-canon-mp140-mp160-mp180-mp210-mp220-mp460-mp470-mp500-mp510-mp530-mp600-mp6... Canon how to reset
2answers
I need Canon MP530 manual
http://www.retrevo.com/support/Canon-MP530-Multifunction-Printers-manual/id/1071dj296/t/2/
Canon MP530 All in One Printer won't print black
Try deep cleaning the black cartridge in the Maintenance section of the printers properties. Print head might be clogged cli-8m
old marine
old marine
ZJ Limited
ZJ Limited
